Cloudy Water After A Water Change?
Discussion in 'Off Topic and Chat' started by rs18alpha, Feb 24, 2018.
  1. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    240
    25
    3:38 AM
    Some times after I do a WC the water gets cloudy.
    Is this normal?
    When I do a basic WC I keep my hob filter on and I use a net with a colander inside to keep the water from disturbing the substrate. When the water goes thru the net it doesn't disturb anything so I know this isn't the cause of the cloudy water.
    Of course when I need to clean the filter I turn it off. When I clean my filter media I use tank water. I always keep the media wet as well.
    Any ideas on this?
  2. Kyalgae
    Kyalgae Lifetime Members
    Aug 25, 2016
    347
    234
    10:38 PM
    If I use my well water, before going through the RO, initially it is clear for a few hours, but I think the high iron in the water starts to precipitate out. This does make things cloudy. If I use even a little bit of this water I get haze. The filter eventually removes the small particles. It might be that.
  3. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    498
    274
    4:38 AM
    What type of water do you use? Do you notice the cloudiness as it comes up or after some time ? How long does it last ?
    If water comes under high pressure, the formation of micro air bubbles as water quickly depressurizes can give a milky color.
