Chlorine removal
[email protected]
Apr 24, 2005
72
63
Vermont
I've just set up a piping system so I can drain and refill directly into my tank. Now I'm wondering a couple things.
First, I can no longer add chlorine remover to the water I'm adding so is it OK to just add it directly to the tank just before I refill? Do I use the same amount as always?
Secondly, I have a whole house carbon filtration system so will this remove all the chlorine and chloramines anyway?
787
Re: Chlorine removal
Whole house carbon systems do remove the Chlorine, as long as you change the carbon on schedule..........
You can also simply squirt the Amquel/Prime etc into the tank as you refill, that's all I've ever done for 32 years.
