Chihiros Rgb 45 + Diy High Powered Led
Ad_ad
Dec 3, 2019
26
Indonesia
Hello, greetings from Indonesia
I recently add Chihiros 45 RGB for my planted tank, so now i’m using 2 lights
1. DIY High powered led (60 watts)
2. Chihiros RGB 45cm(adjustable to 60cm) (37 Watts)
My tank dimension is 60cmx35cmx25cm
I plant rotala hra in the back.
Which is better should i put the DIY Led in the front and chihiros in the back or vice versa to make the coloration better?
AvrilPress
Jul 9, 2020
30
Ashburn, Virginia, USA
Hello...can you please be a little more specific about the lights. Are they IP65, how many lumens, how did you measure the par? PAR of 185 at 30cm out of led stripes is impressive.
