Cheap CO2 mister/diffuser
Discussion in 'CO2 Enrichment' started by camilocastroalvarado, Jun 4, 2015.
  1. camilocastroalvarado
    Aug 18, 2010
    122
    12:57 AM
    Hi everyone.
    I had one of these in-line filters commonly sold in the fertirrigation industry, since they are able to manage big flows (1 inch ports and more) I decided to give it a try as a water polisher in the return pump of my tank. My surprise was that besides clearing my water a bit, it was giving a uniform and nicer/smaller mist compared with the one produced by the pump alone.
    Mine came with 2 1" ports, and 1 3/4" in the bottom that I'm not using, but I will try to inject CO2 directly in there just like the common in-line atomizers works.
    One of the great advantages is that they don't reduce flow considerably and they're very easy to clean. They have a very large surface area so they don't clog easily and you can use them as water polishers.
    I think you guys in USA can get them for less than $15, much cheaper than the big filter housings. You may add the reactor next also.
    Best regards.
  2. chilltyperiod
    chilltyperiod Junior Poster
    Jun 3, 2015
    7
    12:57 AM
    Nice find I would say. But not necessary if you have a good canister filter. So you have put this part after your inline atomizer?
  3. camilocastroalvarado
    Aug 18, 2010
    122
    12:57 AM
    Hi, I'm using a wet dry filter, not a canister. The CO2 is injected in the return pump, then the water goes through this unit before entering the tank. This is actually the inline atomizer.
    Best regards.
