change size barr on a AM 1000 CO2 Reactor
inkslinger
Dec 15, 2007
370
Has any done this before , I would like to change the 1/2 inch bars and tap it out to 3/4 or 1 inch. Any pic would help also Thanks.
Then you have blow out of the bubbles, you'd need new screw in caps with larger pipe inlets.
Simpler to DIY a reactor tube, add the bleed valve, clear PCV, make the in/out any size you wish as well as the reactor tube diameter/length.
It's hardly a high tech device.
dapellegrini
111
45
Phoenix, AZ
Ya I spent a lot of time and energy looking to mod mine to a 3/4" barb - you would think Aqua Medic would make a simple piece... But they don't and the threading on the barb (that you can unscrew from the top) is metric.
If you haven't already bought one, I agree with Tom - just build your own. If you have - the easiest thing to do is just get some 1/2-3/4 barb adapters.
Here are a couple of threads on these DIY reactors that you can build to your own cofiguration and specifications.
http://www.barrreport.com/articles/3444-dual-venturi-diy-external-co2-reactor.html?highlight=reactor
http://www.barrreport.com/articles/...-great-yeast-co2-users.html?highlight=reactor
I agree that building your own is your best bet. Depends on what size/config of your setup.
I used an AM1000 as is in my 180 for a while and it did ok. Just my setup was not good for this and it underperformed for me as I think I overwhelmed it:)
Yes, you would wouldn't you? Do they really think one size fits all?
Hope this helps.
dapellegrini
111
45
Phoenix, AZ
Looks like he did the only thing you can do with it - drilled out the threading on the top and bottom and fitted the new holes with bulkheads.
Great links BTW
inkslinger
Dec 15, 2007
370
This is what auaman3000 said to me :
{I drilled out the 1/2" barbs in each end cap of the AM 1000, then tapped them for the PVC fittings. I then used PVC solvent to glue the end caps and PVC fittings together.}
So it must be just the cap on each end that he tap out and attach the bulkhead to them. But over all size would this work with a higher flow rate of over 1190gph? or should a larger size {3x24} be use . The one I built has a 3/4 bulkhead witch I could use ether a 3/4 x 1/2 , 3/4 x 5/8 or just 3/4.
cggorman
May 9, 2009
42
I reworked my AM1000 to accept CPVC 1/2 MPT adapters. Just cut off the barbs and drill/tap to the correct thread. Those AM1000 threaded endcaps are pretty thick. They don't even need solvent or sealant. Using a pipe thread and teflon tape, mine are completely leak free and completely re-buildable.
In addition to the threaded adapter, I included a pair of elbows on each end to correct what I considered to be poor hose routing for a reactor hung on the tank rim. Mine isn't visible above the light strip and doesn't put any kinks or stress on the hose.
Give me a few hours and I'll put together a drawing. Getting a camera behind there is impossible.
The AM 1000 is actually an old design that was Dupla's old s reactor.
difference?
70$ vs 150-200$
cggorman
May 9, 2009
42
Here's a rough sketch of what I've done. It hangs from the rim in the pictured orientation and top-most piping is about level with the rim top.
  • AM1000.pdf
