Change of substrate
Discussion in 'Sediment / Substrate' started by Gbark, Apr 16, 2011.
  1. Gbark
    Gbark Guru Class Expert
    Jun 15, 2009
    266
    10:00 PM
    Hi All,
    Some advice / your opinions please.
    I would like to change my substrate. Currently my 125ltr tank has been set up and running for several years with Tropica auqacare substrate and gravel on top.
    I fancy a change :)
    I am planning on sucking the Aqua care out with a gravel cleaner, then dropping the water level, i will then take out 50% of the gravel. I would then like to cover with a new substrate.
    I was hoping for a sand foreground for my cory's. I do also use AS in my other tank which i do like.
    What would you do?
    Cheers G:)
  2. Gbark
    Jun 15, 2009
    266
    10:00 PM
    Ahh well, no opions then!!
    I have done the task now, went smooth, new plants in, and fish look happy.
  3. jonny_ftm
    jonny_ftm Guru Class Expert
    Mar 5, 2009
    821
    10:00 PM
    You could give a feedback on how you did. Would be much more informative for us when users contribute with feedbacks, even when they didn't get help.
    If it was me, I'd suck every thing, clean gravel a bit, put the new soil and top it with gravel/sand
  4. Shad0w
    Shad0w Junior Poster
    Aug 16, 2006
    13
    10:00 PM
    If I were you, I will remove the fish, drain the tank take out the old substrate, clean the tank and put new substrate. Basically re-start the whole thing from zero.
