Carbon Filtered water?
AmirM
Sep 26, 2007
40
Israel
Hello,
I was wondering whether I made (and still making) a mistake with my setup.
I used water that goes through a system with a carbon filter and a UV filter- the type for drinking water, not the aquarium dedicated ones. I don't use anti-Chlorine/Chloramine substance.
What do you think? Does the filter deplete the water of Ca, Mg or other trace elements? Will it be better to use plain tapwater with dechlor. ?
Thanks for your input
Amir
________
Videos Pornos
I don't think the filter depletes Ca,Mg or other trace elements, but if you are running more than a trickle of water I also don't think it is removing all of the chlorine. As I understand it, those filters are most effective with a long dwell time for the water inside the filter. I use a carbon filter too, for my continuous water change system, but my flow rate is about a drop per second.
AmirM
Sep 26, 2007
40
Israel
Thanks Vaughn
This filter's output is a low-medium speed.
I will test the tap water and filtered water for KH, GH (just got my GH kit now, it wasn't in stock) - see what we get....
Amir
________
AMERICAN DAD! FORUMS
Carissa
Jun 8, 2007
678
I have a carbon filter on the house and I always use the water, but my tap water is 0 GH and KH anyway even without the filter, so I can't really say whether it would take anything out, if it was there to start with. I always use dechlor though too, just in case.
AmirM
Sep 26, 2007
40
Israel
Dechlor overdose possible?
Hello Carrisa,
Can't we overdose the dechlor? In case it has nothing to deactivate in the water? Do you know what is the chemical compound/s in the dechlor products?
Amir
________
Deposit Premium Forum
Seachem recommends dosing the entire contents of the tank - say 55 gallons of water - not just the amount of replacement water - say 25 gallons of water. And, they recommend adding the whole dose to the remaining water in the tank as you add the replacement water. So, they seem to be saying that a 2X overdose of Prime is not harmful. In fact none of the conditioners is dosed according to how much chlorine or chloramine is in the water, and that can vary a lot, but according to how much water you have. This also suggests that overdosing up to 2X or perhaps more is not harmful. As I recall, from asking Seachem about dosing Prime with a continuous water change system, they are concerned if you overdose by too much. But, I'm not sure how much is too much.
rlillynj
Oct 12, 2007
i hope i dont sound ignorant here, but i also use prime and i add it to the new water and let it sit with a powerhead running for 12 hours before adding it to the tank. so if i were to add the recommended dosage for my entire tank to each new batch of water then i would be adding 5 times the recommended dosage with each water change. that doesnt really make much sense to me. i test for chlorine on a monthly basis, thats every 4th water change just to make sure the prime is working properly and i've never had a trace of chlorine. my only concern has ever been, is prime possibly removing any other trace elements that might be beneficial to my plants. i actually started using another product that claims to just remove chlorine and break up chloramine. i have only been doing this for a month now(4 w/c's) and i have actually noticed better growth. however, right now i'm dealing with green water so i have other variables that are currently affecting things.
I use carbon prefiltered water for my client's tanks, it works well. No issues etc.
Same with carbon in planted tanks, I've seen little issue.
Even if Prime removes all of the nutrients from the water, and it doesn't do so, you will replace those nutrients when you fertilize anyway. So, I don't see it being a major problem. Carbon or zeolite or purigen in the filter might conceivable be a problem since the water is continuously being run thru the filter. But, I haven't seen any evidence that any of those filter media will remove a significant amount of nutrients.
