Can I use slate or shale rocks in my tank?
Discussion in 'Aquascaping' started by rs18alpha, Sep 7, 2017.
  1. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    132
    7
    5:24 AM
    Will these be safe for my tank?
  2. DutchMuch
    DutchMuch Junior Poster
    Mar 8, 2017
    1,033
    384
    5:24 AM
    I have seen slate in tanks yes.
  3. rs18alpha
    Feb 3, 2017
    132
    7
    5:24 AM
    Thanks Dutchmuch.
  4. Jason King
    Jason King barrreport.com
    Nov 20, 2011
    1,538
    316
    5:24 AM
    I've seen and know of a lot of Aquascapes that have used slate, so it's certainly fish safe. however I can't say if it will leech some minerals.. altering the water parameters, raising pH etc.
    Maybe someone else can confirm this?
    burr740 likes this.
  5. bshenanagins
    bshenanagins Junior Poster
    Mar 3, 2017
    145
    85
    5:24 AM
    Depends on how pure the slate is, for instance if you go to lowes and check out their slate tiles, you can see discoloration in some pieces. Hard to say what exactly is in there though
  6. ForTheHalibut
    ForTheHalibut Member
    Oct 12, 2017
    44
    10
    12:24 AM
    Some older aquarium books caution against using slate, but that does not appear to be a prevailing concern anymore. I think it mostly had to do with people collecting rocks from the outdoors, and the possibility of aquarists confusing slate for shale. Slate can also get pretty sharp if you're not careful. If you are confident in your identification and there are no fish-slicing edges, should be safe.
  7. Tim Harrison
    Tim Harrison Member
    Jul 7, 2017
    134
    155
    5:24 AM
    Shale is often soft and will most likely have an impact on water chemistry. This in itself might not be a problem since frequent and substantial water changes used with EI usually reset water parameters within acceptable limits. But it all depends on the type of shale and exactly how soft and friable it is. If it laminates easily and falls apart in your hands, for instance, it's probably best not used.
    Slate on the other hand is often hard. It's a fine-grained, foliated metamorphic rock that is created by the alteration of shale or mudstone by low-grade regional metamorphism. As a result it will usually have minimal affect on water chemistry. I've used it plenty of times without any issues.
    #7 Tim Harrison, Oct 13, 2017
Tags:
