Here is a diagram of my setup:
As many of you know I tried the simple approach first, I am bubbling co2 into the intake of the return pump. The problem is if I set my bubble rate so that I can reach around 30ppm I start getting quite a lot of large bubbles in the tank that just go straight to the top. I can turn the bubble rate down to the point were very few bubbles come out the spraybar but it struggles to be able to hit 30ppm.
My recent endeavor was to make something similar to the Barr internal venturi reactor in the sump were co2 gas buildup in the top was sucked via venturi back to the pump. I've been having some trouble DIY'ing a venturi for my venturi-less pump I am trying to use. I just cant seem to get any suction. So I guess my next step will be ordering something... and before I go any further I wanted to see if there was any way I could adapt my current setup to utilize a Mazzei.
Some things I'd like to do: for one I setup the spraybars to basically cover the entire length of the tank for optimal co2 dispersion and current. So I'd like to have the co2 run into the current plumbing somehow. Would it even be possible to tee my 1" tubing between the RP and bulkheads and have a Mazzei powered by a Quite One 3000 T'd in? Or will the RP be pushing the flow backwards through the Mazzei?
Or it might be easier to T it into the suction side of the RP, but not sure what all will happen to the mist going through the extra pump and few extra feet of line.
I know the obvious solution of putting the venturi inline (like in the 1" vinyl hose) would probably not work due to the low head rating of the pump. Pump is rated at 3600GPH and 12' head. I could possible step up to a higher head pump like the Barracuda, but thats an expensive upgrade not only for the $300 price tag but also 325W power draw vs. 160W. And I would be nervous how much my overflows can handle. I'm already having issues with duckweed clogging the overflows
and been running my Dart pump throttle down to about half until I can get the tank cleaned out.
I am not completely opposed to ripping out all my plumbing and a whole redesign, if someone can see a better arrangement using the Mazzei let me know. The issue here is that the tank is running, I've got some starter plants in it as well as my algae eating crew. So it becomes very difficult to rip out plumbing, especially giving glue a few days to dry, and painting the in tank parts black, etc.
BTW, my diagram is simplistic, and doesnt show things like ball valves, unions, and check valves that are in the plumbing also. Any comments appreciated.
