Calcium Ammonium Nitrate for N?
Discussion in 'Estimative Index' started by tanan, Aug 20, 2014.
  1. tanan
    tanan Junior Poster
    May 11, 2009
    4:13 AM
    Hey everyone.
    I live in Pakistan and all the nitrate products are banned here except Calcium ammonium nitrate.
    Can I use it to replace KNO3?
    If yes then at what dose? My tank is heavily planted.
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    4:13 AM
    Yes. Use Wet's nutrient calculator and figure out the dosage. You'll be adding Ca as well as N in two forms.
    http://rota.la/
  3. Bukhalid
    Bukhalid Junior Poster
    Aug 21, 2014
    4:13 AM
    I thought the NH4 in the "Calcium Ammonium Nitrate" would cause algae bloom.
  4. Bukhalid
    Aug 21, 2014
    4:13 AM
    I thought adding NH4 would cause algae bloom.
  5. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    4:13 AM
    ADA Amazonia contains NH4.
    NH4 is not the cause of algae.
  6. Tom Barr
    18,690
    706
    4:13 AM
    NH4 loading from more and more fish seems to cause algae.
    NH4 up to say 1 ppm per day does not seem to from inorganic sources. Plants will not need/use more than 0.8 pp m to maybe 1 ppm per day under 99.99% of cases.
  7. tanan
    tanan Junior Poster
    May 11, 2009
    4:13 AM
    Thanks everyone. Tom does that mean I need to dose CAN daily under 1ppm of Ammonia or otherwise there will be free ammonia?
    How do I calculate what percent/amount of my dosage has how much ammonia?
  8. Tom Barr
    18,690
    706
    4:13 AM
    % NH4 in the molecular formula weight/water volume in liters or milliliters.
    Say the NH4 is 25% of the Calcium ammonium nitrate. So 0.25 x molecular weight of Calcium ammonium nitrate
    Then say you want 0.5 ppm of NH4 in a 100 liter aquarium. 1 Millligram/liter = 1 ppm.
    So 50 milligrams of Calcium ammonium nitrate is required to dose 0.5 ppm.
    I do not know the weight or have a calculator etc.........of product you are using nor the %, but that's how you'd go about it.
  9. ak24
    ak24 Junior Poster
    Dec 28, 2014
    27
    4:13 AM
    Tom,
    You mean 1 ppm NH4 compound or 1 ppm No3 from NH4 compound (+-0,34NH4) ?
