In answer to questions I was never asked. Being a busy body I can’t help wanting a crack at it…
The whole thing seems to be around KH and coral.
First “pH” as I (mis?)understand it.
I have heard many explanations for what pH stands for;
The ratio of hydroxyl ion [OH-] and hydrogen ion [H+] concentrations determines pH.
Acids give up (donate) hydrogen ions, bases take (accept) hydrogen ions.
Crushed coral is Calcium carbonate, CaCO3. Calcium carbonate occurs naturally in its crystal form in three polymorphs or trimorphs,
Calcite, Aragonite or Vaterite it is all CaCO3.
In a sense it is a trick question, since Calcium carbonate in any form will only dissolve easily in acidic or less alkaline water, up to around pH 8.5-8.8. As an acceptor of electrons it “buffers” the water, reducing the acid content, raising the pH or preventing it from falling.
- How does adding Coral sand (Calcium carbonate) cause pH go up in a freshwater tank? Given that Calcium carbonate doesn't contain any Hydroxyl ions as bicarbonate of soda does.
- Floating around there seems to be some confusion as to what Coral sand is and should it actually be crushed Aragonite crystals; would that explain the pH rise as it is erroneously thought this contains Hydrogen ions.
- I will stick with “p” being a mathematical symbol for a negative log function and “H” being the chemical symbol for Hydrogen;
- pH=-log [H+]; to chemists and such like folk these “[]” square bracket thingies indicate concentration.
- For those demanding more precision, pH is the negative logarithm of the hydrogen ion concentration: pH= log 1/ [H+= −log [H+]] (had to look that up.
- Therefore even though pH is by definition a (selective) measure of Hydrogen ion activity, it is actually a measure acidity and alkalinity.
- the most abundant and stable form, the trigonal (bar 3 2/m) symmetry, Calcite,
- the abundant but somewhat less stable orthorhombic (2/m 2/m 2/m) symmetry Argonite
- and the rare hexagonal (6/m 2/m 2/m) symmetry, Vaterite.
