CaCL2
fresh_newby
Apr 2, 2006
68
NYC
Tom:
How do I know if I should dose CaCl2?
My kH is 3-4 and my GH 2-3, and I dose EI Using only MgSO4 with CSM+B for traces.
Do you see a noticeable deficiency in plants that would require CaCl2?
Re: CaCL2
CaCl is not actually dosed like other fertilizers. It is used to add calcium hardness to water with too low GH. Adding calcium and magnesium (epsom salts, for example) is a way to jack up the GH. Generally it is done at water changes only. I think I am correct about that.
Re: CaCL2
fresh_newby said:
usually you dose Mg with traces every other day accoring to EI...no?
I have dosed Mg with the traces, Mg once a week, and no Mg at all. I couldn't see any difference among those options. My tap water has some Mg in it, according to the water company report, so I doubt that I need it anyway.
775
Re: CaCL2
I think it's safer to based your assumptions on both Mg and Ca.
So add something like Greg's GH booster, cheap and has both in it already.
You can also use CaSO4, does not dissolve quite so fast, but will within a few min/hour etc.
