Hi all,
One of the most difficult things regarding c02, at least for me, is that I have read in many places and for many size tanks, regardless of size, that the c02 rate is 3-5 bps. It never seems to vary much despite scape, flora, size, etc.
I realize that bubble size is different all over but still, unless that bubble is the size of a basketball, there is no way it could supply a large tank fully planted
Let's assume a lot of folks use the same approx size of tubing and a decent dual stage reg and good NV. Can there be THAT much difference in the size of the bubble or the amount of c02 per bubble? Does that make sense?
So, over the years I have read this in Amano books and various publications that it is stuck in my head. When I compare that image to my REAL and ACTUAL bubble rates, it seems ludicrous to me that enough c02 is supplied at least WHEN COMPARED TO MY USAGE!
To compare I now have TWO c02 regs on my 220. One is at each end of the tank and blows lengthwise the tank. The vortech on lagoon mode helps distribute this around. The NW is a rio 1000 so adds a bit of flow as well as the c02.
1. They are both high quality brand new victor dual stage, ideal NV, burkert solenoid, swagelok post body, etc. All brand new components.
2. The one reg feeds an UP AQUA co2 16 mm atomizer inline with one of my Eheim canisters. PSI here is set to almost 30 to feed it properly. Even if the PSI were turned to say 10, the bubble rate would be best described as 'turbulent' if the end of the tube is placed in a glass of water.
3. The second feeds a DIY rio 1k needle wheel. Here the PSI is set to 10-12 and the bubble rate was set to a single bps (as near as I could tell) and then I started increasing this rate every 2 days and watching the fish and plants.
This rate is also much more than 3-5 bps
Not 'turbulent' but not like you can count the rate either....at least I cannot
So far the addition of the second c02 supply seems to be helping. The plants seem larger and the growth rate seems better. The fish and shrimps all seem fine and no issue with the extra c02.
This has been ongoing for several weeks to adjust/increase c02. I am only increasing c02 now via the RIO NW.
Tom has been encouraging me to ignore the bubble rate and concentrate on the fish and plants as I have been doing all along.
I do this anyway, but still sometimes look at the amount of c02 I am pushing for my tank, and think, well compared to Amano or Knott, etc that I am doing something wrong since my rate is so much higher than the published rate.
I have trouble I guess with the amount of c02 I 'see' going into the atomizer or NW and think, my goodness, that is a lot of c02, and SHOULD be sufficient.
But, the reality is that it is NOT enough for the plants, at least in my setup.
So, this is my own personal demon myth apparently....
Just wanted to get others thoughts and experiences.
