I'm in the process of building a new planted display tank for the LFS that I manage. I have a good idea of what I would like to do with the hardware and fishware involved in this project but I really wanted to run it by you guys for your input before I commit to anything.
My store specializes in reef and planted aquariums and is undergoing a major upscaling/remodel. Our remodel is a kid-in-a-toy-shop type of scenario in which our resident reef geeks get to build-out two new 215 gallon Oceanic Ultimate Starphire no-holds-barred reef displays. The first reef display will be a soft coral, LPS, anemone tank with loads of gorgeous fish and inverts. The other reef tank is a hard-core SPS, high-light, high-flow tank full of tangs designed by our resident marine biologist.
As the store manager (and sole freshwater geek in a store full of salties) my job is to build a planted display that will compete with these two monster reefs. Fortunately we have a custom acrylic fabricator who does incredible work. Sitting next to these two hulking reef setups is a 190G custom acrylic planted display that they built to our specifications. It's hard to imagine a 190G looking like a small tank (unless you're Tom), but next to these two behemoths, it does seem little petite. Its dimensions are 60" long x 24" deep x 30" tall. The top is open with a 3" lip and no center bracing (it's wide open) which allows the use of a hanging fixture (no canopy or lid) and will allow me to aquascape it with hardscape/plants emerging beyond the top of the tank. The hardware is already in place and I will get some pics of the empty setup and post them in a day or two.
I've worked with large plant displays before but have never had a chance to play with something of this scale. It's hard to describe how tall 30" of planting space is without standing in front of this thing and looking at it. Five feet wide, two feet deep, and thirty inches tall, oh the possibilities
Before I get to my questions I should detail the hardware that is going to be used and my plans for fish, plants, hardscape, etc. Filtration will be done with two Nu-Clear canisters - models 533 (mechanical/chemical: 25 micron mesh and loads of Purigen) and 547 (biological) - driven by a BlueLine T3 in-line pressure-rated pump. The canisters will be plumbed in parallel with a Mazzei 584 (3/4") venturi loop for CO2 injection. Water flow from the canister and venturi lines will re-unite and then be split back into two separate return lines, each with Hydor 300w in-line heaters, and exit back into the tank via ADA P-6 17mm lily pipe outflows.
Lighting will be done with a 60" Current Outer Orbit Pro 2x250w MH, 4x54w T-5 fixture using 8000K ADA MH lamps and Giesemann 6000K Midday T-5 lamps, giving the tank roughly 4 watts per gallon of light.
The fish will be South American soft/warm-water species: discus, cardinal tetras, Dicrossus, Apistogramma spp., etc. Plants will be Tonina and Eriocaulon-style species that thrive in the same warm, soft-water conditions. I'm planning on using ADA Aquasoil as the substrate (no Powersand, to avoid the mess it causes when uprooting stem plants and other root-feeders, as well as the associated nutrient spikes), with a bit of extra peat and mulm beneath it, a Bright Sand foreground, and some select pieces of manzanita wood for hardscape.
I've already got most of the hardware but now that I can actually look at it I have some doubts. The ADA P-6 lily-pipe outflows look adequate for the job but the V-7 inflow pipes, even though they're the largest glass pipes available from ADA, look like toys in this tank. They only drop down about 10" from the top of the tank, which leaves a good 20" gap to the bottom, not very deep for intake pipes, IMHO. And the cut glass screens on these lily-pipe intakes appear so small and limited that I can easily imagine the BlueLine T3 pump imploding them when I fire it up for the first time. I am considering ditching them and having standpipe intakes drilled into the bottom of the tank instead. These intakes could easily be hidden in the plants and would give me a lot more confidence. Thoughts?
The wood I plan on using I hand-selected from over 200 pounds of manzanita pieces that we received. It is very nice looking but I've heard of people having issues with toxicity and buoyancy with manzanita. I can easily soak it and/or anchor it but I still worry about any lingering toxicity because of the somewhat delicate nature of the fish species I plan on keeping. Has anyone had any issues with this type of wood?
This will be my first Mazzei venturi injection CO2 system and I have researched it as much as I can, selecting the hardware that I think will best suit its requirements. If anyone has any input or experience regarding best practices with Mazzei venturis for CO2 injection I would greatly appreciate it.
I think that's it for now although I'm sure there will be many more questions to follow. My thanks to anyone who has managed to read all of the way through this rambling post
