Bubble Counter Won’t Hold Water
Discussion in 'CO2 Enrichment' started by tiger15, Nov 2, 2018.
  1. tiger15
    tiger15 Member
    Aug 12, 2017
    232
    80
    5:15 PM
    My bubble counter won’t hold water for more than a week. I can see slow dripping at the bottom of the counter yet soap bubble testing did not show a leak. Is the dripping caused by condensation or water forced out by pressure?
  2. guy4123
    guy4123 New Member
    Nov 3, 2018
    2:15 PM
    Is there an o-ring seal at the bottom of the bubble counter? If not, there will probably be leakage, otherwise try tightening the two ends that are attached to the acrylic body of the bubble counter. That might compress the o-ring better.
Tags:
