Brown algae outbreak?
Discussion in 'Marine Plants - Macroalgae' started by For100, Nov 20, 2011.
  1. For100
    For100 Junior Poster
    Feb 5, 2011
    33
    10
    1:23 PM
    My new set up seems to have an outbreak of brown algae. Please help me make sure it is brown algae.
    It is a brownish slime on the walks and sword leaves. It is easily removable by hand, in some instances grows into small hairy areas.
    It accumulates as dust in the bottom of sump tank. It does not stick to anything there, you can remove it by just syphon the bottom.
    The tank has been established for about 2 months, plants are growing a good pace and don't show any nutrient deficiency. I use the EI method to fertilize every week.
    Details:
    Volume: 180 Gallon
    Lighting: 6 X 45 watts bulbs
    Fertilization regimen:
    KNO3: 2 teaspoons / week
    Flourish K: 50 ml / week
    Micro nutrients + iron + Boron: 1/2 teaspoon / week
    Excel: 100 ml / week
    Substrate: play grown sand
    CO2 system injection
    Current Readings
    pH: 6.5
    KH: 5DH
    GH: 9DH
    NO3: 5ppm
    PO4 < 1ppm
    Chelated Fe ~0.5 ppm
    What do you suggest to control it View attachment 2576 View attachment 2574 View attachment 2575 View attachment 2577 ?
  2. Cyclesafe
    Cyclesafe Guru Class Expert
    Jan 19, 2011
    136
    1:23 PM
    Diatoms are normal for a new tank. Nerite snails work amazingly well. Is your sump exposed to light?
    More water circulation will help.
  3. For100
    Feb 5, 2011
    33
    10
    1:23 PM
    Thanks for the quick response.
    It is the first time I experience this kind of problem. I was hoping to come across someone with similar experience and let me know what nutrient is creating the algae outbreak.
    I have a 1200 Gallon/hour pump in the sump tank and Koralia NaNO 425 (~400 gallon / hour) for circulation in the tank itself.
    I am planning to do a 50% WC tonight and only add 2 teaspoons of KNO3. Reading show it is close to zero.
    Should I reduce the Excel intake as well?
    FR
  4. Cyclesafe
    Jan 19, 2011
    136
    1:23 PM
    If it is diatoms (brown "algae") then as the tank matures it will go away. Some in the past have postulated that diatoms are the result of too much dissolved silicon - maybe, but good luck with doing anything about that.
    Frequent water changes will help. I don't think diatoms are influenced by EI or glutaraldehyde.
    Usually I'm not a fan of relying on animals to control anything, but I must say that nerite snails are incredible. Dump 30 or 40 in your tank and they will line up like snow plows on a runway and make short work of your diatoms.
    I don't think it is a direct cause of your diatoms, but I noticed that you don't add phosphate. Also, you might consider spreading out your Excel and micros dosage over the week.
    #4 Cyclesafe, Nov 20, 2011
  5. For100
    Feb 5, 2011
    33
    10
    1:23 PM
    I have let the tank try to settle. The lastest picture is attached. Please let me know what you think about the green algae growing on the walls and older leaves.
    What is driving the imbalance? NO3?
  6. For100
    Feb 5, 2011
    33
    10
    1:23 PM
    [attachment=902:name]
  7. For100
    Feb 5, 2011
    33
    10
    1:23 PM
    last picture
    [attachment=904:name]
  8. Crispino Ramos
    Crispino Ramos Guru Class Expert
    Apr 23, 2010
    278
    1:23 PM
    I know it's a lot of worked because I've had tanks with diatoms. Don't give up on cleaning the glass, plants, substrate, rocks, intake and output pipes, canister, etc.. Keep doing water changes and eventually/gradually it will diminish and disappear.
  9. richardsantink
    richardsantink Lifetime Charter Member
    Apr 3, 2005
    51
    1:23 PM
    I find this quite normal when I do large water changes, as it seems to be tied into silicates, with regard to the quality of the salt I was using. After my water change (of about 30g for my 125g tank), I run into this for about two weeks if I just leave it. Lately I've been mixing my seawater a week in advance, and polishing it in my barrels before adding it to the tank. It's made a huge difference but there is always some still.
    R
  10. Biollante
    Jun 21, 2009
    1:23 PM
    Shhhush
    It is what I found living in the Salt River valley.
    • I can produce brown algae at will just use unfiltered tap water.
    It upset many on this forum so I was asked (told?) to shut-up about it since “they” had “settled science” that diatoms have nothing to do with silicates.
    You might want to consider a whole house sediment filter, cheap and effective…
    And if anyone asks you did not hear it from me.
    :cower:
