Technically you could. You will need to adjust how much amount of Borax you will need to reach desired ppm.
Also Borax has sodium so you will be adding some sodium to your water. At amounts we desire it should not mater but a build up should be avoided.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
