After 3-4 months, the base stems of my Blyxas rot or turn to mush.
They attach to the substrate only by roots from the healthy stems.
Technically, they are floating 1-2" above substrate. The upper parts of
the plants are OK. Is this normal?
This happens to Heteranthera Zosterilfolia too, which is also stem plant.
I think the substrate is still OK, in terms of aerobicity.
Because all other rosette plants (Vallisneria, Tenellus, Vivipara) don't have
this problem.
This makes me suspect that it's because there is too
low nutrients in the plain gravel substrate, especially the less mobile ones.
So the nutrients received from the leaves can't move to the base stem
for stem plants. Rosette plants don't have this problem because
almost all of their structures are made of leaves.
What do you think?
Thanks.
this problem.
What do you think?
Thanks.
