Black Diamond Blasting Sand
inkslinger
Dec 15, 2007
370
Been thinking of this sub from the Tractor Store called black diamond blasting sand , I know it has other sizes that are stamp on the bag ,but what they have all the time is 30-60 grit size , Wounder if it comes any bigger. Has any one use this in this forum. I find it to be a little to fine for me but hear others having good plant growth for $7.99 50lb bags any one have pic's of your tanks with this.
Strgazr
Oct 21, 2012
55
Blanchard, OK
I am using Black Diamond in one of my aquariums. I got the 20-40. The 30-60 was much too fine. I absolutely love it. It is super easy to plant in and the color is great. I'll try to get some pictures in a bit.
1077
Aug 19, 2010
189
Not smart enough to post picture's, but I too, use the Black diamond 20/40 grit in 300 litre planted tank.
Have corydora's,shrimp's,and have seen no ill effect's from this substrate over a year now.
mike
Jan 13, 2012
169
Quebec, Canada
I use black diamond 20/40 in my 125g tank. I use it as a cap, about 2 inches over a soil substraight. I really like the contrast it provides with the plants.
Mike
inkslinger
Dec 15, 2007
370
Can this be use to dry start low cover plants , And what would be the best way to start this using a 60x18. Do I just keep the sub moist and spray the plant's every day? do I mix dry fret's to spray on or moist the sub with?
AaronT
Jul 29, 2013
195
I wouldn't use it just by itself for a dry start. You want to use a substrate with some nutrients in it like Aquasoil or mineralized soil, etc...
inkslinger
Dec 15, 2007
370
Will mixing the dry Fert's would add the nutrients in the soil after time ? Maybe add a layer of Laitright on the bottom and mix the dry fert's to wet the gravel then spray every other day . I wouldn't know how much to mix for a tank 60x18 tank with 3 or 4 inch of gravel. I got a foggier I can throw in there in a bow of water and put it on a timer to keep things moist.
AaronT
Jul 29, 2013
195
Yes, that would probably work okay.
reef12
Apr 29, 2013
534
Tulsa
I use it too, but have to remember especially on a glass tank is that it is a blasting sand. and can and will scratch a glass tank easy.
Jeff
