BGA eradication and prevention.
chris81
Mar 31, 2008
72
41
Malta
HI guys,
Next week im planning to flood my aquarium which is currently running emersed method since august. About 3 days ago i however noticed a black tread like thing growing on some of the substrate and glosso leaves. On consultation of this forum i deduced its most probably the dreaded BGA. Now the most common treatment for it is erythromycin which is no longer available in MAlta because of wide spread resistance to it. I am a pharmacist so i have clarithromycin and azithromycin anti biotics available. Now clarithromycin is not water soluble while azithromycin is and both have a smiliar spectrum of activity. SO would you guys suggest that i use azithromycin 2.5mg in a liter of water and spray substrate using a mister for this week prior to flooding. Would i cause plants any damage??
Just on a side note would it be wise to use 2.5mg/L of azithromycin on alternate days as a prevention for about a week after flooding?? Just to be sure. I know resistance would be an issue but would it be worth the risk??
Thanks a million.
Chris
chris81
Mar 31, 2008
72
41
Malta
I have also come across individuals sugggesting ten drops of tea tree oil in a liter of water. Has anyone ever tried this.
Thanks again.
I'd black the tank out for 3 days prior to flooding.
Then add KNO3 etc from then on.
chris81
Mar 31, 2008
72
41
Malta
Thanks a million Tom,
I will do as you say. Today i did spray mist some azithromycin on the affected areas. Will see how it goes. I read articles that state that nitrate deficiency is the reason that BGA flourishes. I will be trying reconstituted brighty (as suggested by this site). Brighty K daily and Brighty special lights 3 times a week (without ammonium) and micros by seachem twice a week with weekly half water changes.
Hope all goes well. WIll keep all posted.
Thanks again for help
Much appreciated as always!
Philosophos
1,346
I believe tea tree oil is pretty broadly biocidal, it'd work. I've also seen some publication in journals about the allelopathic effects of the terpens found in it, though I haven't seen anything about dose besides levels in excess of 1,000ppm solutions. From what I can tell the density of these compounds doesn't excede 1g/ml and I doubt if 10 drops would be more than 1ml, so you'd probably be starting in around 500ppm.
No idea on the antibiotics. I've tried a couple others and found them ineffective, but I'm not sure about their spectrum beyond being gram negative.
chris81
Mar 31, 2008
72
41
Malta
Cyanobacteria are Gram negative bacteria and azithromycin has a more poweful gram negative spectrum than erythromycin so in theory it should work. However i ll keep you posted as what has happened in vivo. I will still be doing a three day blackout prior to flooding so as to make sure all starts on the right footing. I would love to test with tea tree oil too, but i ll leave that as a last resort in case another outbreak of azithromycin resistant BGA emerges after trial!! (Hope not)
Cant wait to flood now, it has been too long!!!
:p
