Best place to add a Drop checker?
Discussion in 'CO2 Enrichment' started by reef12, Aug 15, 2013.
  1. reef12
    reef12 Member
    Apr 29, 2013
    534
    12:04 AM
    Wondering if far away from the stream as possible, I do have a kind of slow spot in the 125.
    Jeff
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    I asked the same question not too long ago. The simple answer is that it doesn't really matter since the trapped gas eventually equalizes with the water. So you should really put it in a place that is easy to see and not distracting.
  3. Socket
    Socket Prolific Poster
    May 5, 2013
    58
    12:04 AM
    In the classified section? ;):wink-new:
  4. Tom Barr
    18,691
    711
    12:04 AM
    In the garbage?
  5. ShadowMac
    ShadowMac Lifetime Members
    Mar 25, 2010
    1,043
    13
    12:04 AM
    LOL!
    why do I still use one!?
  6. Asmack Arabia
    Asmack Arabia Banned
    Nov 1, 2012
    145
    12:04 AM
    i think its still a good back-up or reminder to let us know if our co2 is ok. my co2 system is at the back of the cabinet which i seldom got to check. a number of times happened where my co2 was malfunctioning and i only happen to know because my drop checker turned green or blue (it's always yellow). so i still keep it in my tank.
  7. Socket
    May 5, 2013
    58
    12:04 AM
    A little more brash than my suggestion...but how I feel as well.
  8. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    If the only issue with drop checkers is the extreme amount of time lag (hours) before it tells us the CO2 concentration, then there are ways to improve upon it so that it's immediate, less than one minute. All that is required is to agitate the solution so that the gas diffuses much faster.
  9. Asmack Arabia
    Nov 1, 2012
    145
    12:04 AM
    i haven't thought about that. can you tell me exactly how to do it ? like how many drops of solution to ml of tank water ? do you shake or swirl it ?
    thank you.
  10. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    A small stainless steel ball bearing (one you can get from skateboard bearings) can be placed inside the drop checker if the opening is large enough. Moving a magnet outside the tank next to the drop checker will cause the bearing to move thus creating agitation of the solution. The only downside is that it is manual. Something automatic requires something more complicated.
  11. Tug
    Tug Lifetime Charter Member
    Jan 5, 2009
    1,150
    12:04 AM
  12. Asmack Arabia
    Nov 1, 2012
    145
    12:04 AM
    i was thinking of doing the testing outside the tank. like you put an X amount of tank water in a cylinder then add X drops of the solution, shake, then you get an instant result.
    is there such a thing ?
  13. BriDroid
    BriDroid Prolific Poster
    Dec 28, 2012
    34
    12:04 AM
    That is a nice idea. I'll have to see if I can find a small enough bearing.
    Would the indicator solution or the KH solution cause the bearing to rust, meaning I would have to change the drop checker solution out more often?
  14. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    That's the same as testing for pH. And if using the pH/kH table, that also requires testing for kH to measure the amount of CO2.
  15. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    It depends on the quality of the stainless steel bearing. If there were ceramic bearings with a steel core, that would never rust. But I don't know if it anyone manufactures such a thing.
  16. Tug
    Jan 5, 2009
    1,150
    12:04 AM
    I think you can get very close checking your pH independent of KH, to determine CO2.
    Let your tap water sit for 24-48 hours to gas of any CO2 and check the pH.
    Next, in your tank, check your pH after you've started to add CO2.
    A one degree drop in pH should equal a 10x increase in CO2. :encouragement:
    So, it can be done without knowing your exact KH.
  17. reef12
    reef12 Member
    Apr 29, 2013
    534
    12:04 AM
    Can't use a Magnet with stainless steel, if all Stainless.
    Okay so some don't use one then, nice answers though.:eek:
    Jeff
    #17 reef12, Aug 21, 2013
  18. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    12:04 AM
    Stainless steel will contain iron so there is a magnetic attraction. The power of the magnet may not be strong enough if it isn't close enough to the steel. In any case, anything that can rust will eventually rust unless you coat it with some kind of clearcoat. Another issue is that the CO2 must outgas into the drop checker cavity. This can be a slow process so a device that can also agitate the aquarium water as well as the dkH solution will increase the speed of the drop checker reading.
  19. Tom Barr
    18,691
    711
    12:04 AM
    Well, this ASSUMES the degassed water is in fact, degassed. Some of the estimations using pure RO and baking soda suggested many canister filtered aquariums still had a good 10 to 15ppm left over.
    So if you think you have 2-3 ppm, when you have say 15 ppm, then you add another 30-40ppm.............what could go wrong?
    A lot.
    Say your measure of pH is rather poor, or the pH probe has not been calibrated, or you think it is.........again, another source of errors.
    So things need to be looked at carefully and checked to make sure the readings are correct.
    Not quite as simple as we'd like.
  20. Tom Barr
    18,691
    711
    12:04 AM
    A lot.
