Beginner question - Dry Start Method
Discussion in 'Are you new to aquatic plants? Start here' started by bonga, Aug 10, 2014.
  1. bonga
    bonga New Member
    Apr 2, 2014
    8:31 AM
    Hi All,
    Understand that there's sticky post already about DSM. But since the thread was locked, with all my respect to member here i would like to seek some advise on my current DSM.
    Below is some question which i dont quite clear yet.
    1. Water level - I saw on Tom's thread about DSM and if i'm not wrong the water level is just right same level with lowest side on our tank. But also i saw many post about DSM, they didnt put any water on the tank. Its only use spray and mist maker to make the soil moist. Question is which one i need to follow ? Non water or water ?
    2. Moist and temperature - What is the maximum moist level for DSM ? I'm using hygrometer and it's showing 80-90%. Also for temperature, since i'm wrapping my tank and use light for 10 hours, temperature can hit 30 degree celcius.
    3. Saran Wrap - Saran wrap is utilized for keeping the moist right ? If i can maintain the moist using mist maker, did i still need to wrap my tank ?
    For your reference, i'm living at Indonesia which is pretty humid like Singapore. And my tank size 90*40*50.
    I hope anyone who successful with DSM can share to me.
    Thanks a lot and have a good weekend.
  2. Whiskey
    Whiskey Member
    Jun 14, 2010
    368
    8:31 AM
    I kept my tank at about 70% humidity, I had it much higher, around 95 and ended up getting a mold or fungus that damaged some of the plants, after backing off that went away.
    I didn't worry about temp, I expect mine was getting that high too, but one thing I did make sure of was that the water line was never visable. Standing water will lead to problems, but as long as the water level is under the substrate it should be okay.
    One last thing, to attain that humidity level I found I couldn't cover it with serran wrap entirely, I had to leave a gap of about an inch or two open in the back. I'm sure this was good for getting new CO2 rich air in the tank as well.
    Whiskey
  3. bonga
    bonga New Member
    Apr 2, 2014
    8:31 AM
    Thanks Whiskey, appreciate your kind feedback
  4. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    8:31 AM
    I kept the tank open during DSM. This prevented mold. I also kept the water level as low as possible without drying out. I placed the tank by the window and used sunlight to drive growth; cheaper than using electricity. I misted it every now and then to add moisture back that had evaporated. I think I waited 2 months or so before flooding.
