Hi S,
I'll try as best I can to answer your questions.
shoggoth43;92718 said:
I noticed how high the water got when you started your pump before it settled down. I was curious where your valve was as I had similar issues with the herbie I'm using.
I had the same issue you mentioned. I did 2 weeks worth of leak tests and stopping and starting the pump and I did have problems with water going over to top of the external overflow. After doing some research I found out that the main drain has to be not more then 1.5 to 2 inches below the high water line, in my case that is where I have the black tape. I was told that if the main drain is too deep in the sump then there is too much pressure for the syphon to be created. When you look at the sump section of the video you'll see the drain on the right, the main drain, is higher up in the sump that the backup drain, the one on the left. Another way to avoid this problem is to start with a 1 inch bulkhead then right after to bulk head, and before the gate valve, you enlarge to 1.5 inch pvc, which is something I plan on doing eventually.
It looks like your tank was originally drilled for 1-1.5 inch bulkheads. Was there any reason why you have the holes at mid overflow level vs down near the bottom of the overflow?
Those are 1.75 inch holes, for a 1 inch bulkhead. all I had was a 1.75 inch drill bit. The center of the holes are 3.5 inches from the rim of the tank, which puts them in the upper 1/3 of the weir. My thinking here was that the higher the holes the high the water level in the weir so less of a drop for the water. I also figured that if there was too much flow through the holes it would be easier to silicone some glass to block the lower 1/2 or 1/3 of the holes.
What kind of a drop over the internal box do you have? It looks like a couple of inches.
The internal weir is 6 inches deep and the drop from the top of the weir to the top if the water is a little less than 2 inches. I could have made the internal weir 4 inches deep.
Also, did you make any calculations on the overflow box length or did you just pick a length and then get a pump big enough to put enough water over the full 4 foot length?
No calculations, just logic and lots of reading. My thinking was it didn't matter too much how much flow I had, the water would flow over the top regardless, and if I put the holes high enough in the internal overflow then there would be less of a drop. I chose a longer overflow because I wanted a nice even skim off the surface. During my leak testing I also ran a pump that was only 400gph. There was more of a drop to the water, I would have to say close to 3 inches but with both drains deep in the sump I never had a problem starting the full syphon. The full syphon is a problem when you have high flow pumps.
How "deep" is the water flowing over the weir?
there's about 1/4 of an inch flowing over the top of the weir.
All that said. There are a few things I would do different with this project.
1. I would use a 1.5 inch drain after the 1 inch bulkhead. this would increase the flow and result in a better startup of the full syphon.
2. I would make the internal weir about 4 to 5 inches deep rather than 6.
3. I would make the external overflow deeper. Right now it's 6 inches but I want to raise the backup drain but I have no room. I would make it 8 inches deep.
Hope this helps
Mike
