Initially I was trying to design a built-in overflow that is both silent and almost invisible.
The fact that I do not want to paint the back glass, it makes the second requirement very hard to be achieved.
Several people here in this forum enjoy their hang-on overflow box. Its flexibility and external design obviously help achieving a cleaner presentation. However, this benefit does come with water damage risk.
In order to mitigate this risk, I am considering the following hybrid design:
* Hang-on overflow with two stand pipes: Full Siphon + Open Channel
* Plus the drilling of one hole in the tank for the Emergency stand pipe
Of course the diameter of the hole drilled should match or surpass the other two in the hang-on box, following the BeanAnimal specs.
In my situation I would place the hang the overflow on my less visible side and drill the hole in the back.
Disadvantages (when compared to a pure hang-on approach):
* Having to drill one hole, instead of none.
* A little more clutter: bulk-head and stand pipe.
Advantages:
* As safe as a Bean Animal built-in overflow.
* No need to have any built-in overflow box and aquascape around it.
* The only stand pipe visible in the back, (emergency), would be dry, allowing someone to use clear PVC without having to deal with algae.
I am looking for your invaluable feedback before I put this plan in motion.
Cheers!
Advantages:
Cheers!
