Bba In Low Tech Tank!
Discussion in 'Introductions' started by c0mrade5, Mar 26, 2018.
  1. c0mrade5
    c0mrade5 New Member
    Mar 26, 2018
    2:08 AM
    I have 200l tank,1200l/h subbmersible pump wich i run few hour a day just for flow i dont use the tube for air,Light is 2 14w Led 6500k tubes,and for the fertz as tom said i took 3x EI dosing,i cuted that to x1 (once a week)and cut that x1 in 1/3,im using diy dry fertz witch i have dissolved in water,1 bottle micro other one macro,dosing x1 as i said from both fertz at the opposite side of the tank,i was doing weekly wc but i stoped that for about 2 months as tom said to stop doing wc,i had bba then i have bba now,nothing changed.I hope to get answer from tom barr!
Tags:
