Hi all,
I have had some issues lately with BBA taking over a good portion of my manzanita wood and my rockwork.....
A lot on the stauro but not on the other plants so much just a bit. The hardscape was looking bad...
Over the last 2 weeks I have done my best to battle it with every other day large water changes, dosing, trimming, etc. Monitoring/adjusting c02 a tiny bit...
I also removed some of the bulbs that lit nothing basically but the wood. With no attached plants, the wood was getting LOTS of unrestricted light. The plants below the wood were Java species, so why so much light, he asked rhetorically?
These prcatices have had a positive overall effect, but the rocks and wood were still very bad with BBA.
To hasten the cleanup I decided to try using excel to soak the rocks and wood if possible.
I poured a few ounces of excel into a 5 gal bucket and filled 1/3 with tap water. I then removed each rock and simply 'swished' it around the bucket, ensuring that it was submerged and all surfaces got soaked. Less than 1 minute per rock lol
I removed the more complex wood from the right side and then poured the contents of the bucket slowly over the manzy wood ensuring to cover it all. I held the wood over the sink.
I then did the same in tank for the other manzy wood. But since this water ended up IN TANK, I made a weaker excel solution.
Results within 48 hours showed the BBA slowly turning paler on the rocks and wood. Things seemed 'clearer' and the stauro seemed fresher/newer and less algae ridden.
I then went away overnight and now within another 48 hours and the rocks are completely devoid of any algae and are very clean. The stauro is almost completely cleansed as well.
The wood is much better and was much more infested so may take a bit more time or another application.
I forgot to take before pics but trust me it was pretty bad, esp the rocks and wood.
So just thought I would toss this out as my experience using this tool for this specific cleanup issue. I think others have also had this experience.
So, much less work than scrubbing with a toothbrush. Did a better/quicker job too
So, now to ensure that I have fixed the root cause(s), but growth is good and I see no NEW algae, but the existing BBA is resilient as you all know
Root cause was simply too much light but we will see now that light is reduced quite a bit over the wood esp and we have a clean hardscape to benchmark against...
Later.
Later.
