Since there has been a number of emails as to the appropriate parts for these two basic configurations, I though I'd start a thread to help people. These are configured for standard 4mm/6mm ID/OD pressure resistant tubing.
Step 1: create an online Swagelok account to order and buy direct. Simple process that takes only a few minutes.
http://www.swagelok.com/?showLogin=N
Enter part number in "search" area on website for pics and ordering.
(for stainless steel, substitute "SS" for "B")
These part numbers are in order from regulator to tube adapter.
VTS250 series type regulator:
B-4-HRN-2
B-2-SE
Solenoid (w/ female 1/8" npt ports)
B-2-HN
Needle/Metering Valve
B-2-HN
B-2C4-1/3 (female threaded check valve)
B-6MO-1-2
B-6M5-4M
Or
My favorite way:
B-4-HRN-2
B-2-SE
(solenoid)
B-2-NH
(needle valve)
B-2C2-1/3 (male threaded check valve)
B-6MO-7-2
B-6M5-4M
For those of you who are hellbent on using a JBJ bubble counter:
B-4-HRN-2
B-2-SE
(Solenoid)
B-2-HN
(Needle Valve)
B-2C2-1/3
JBJ BUBBLE COUNTER
Should look like this:
HPT/BHT/SGT 500 Series Type Regulator (90*):
SS-4-HLN-2.00
SS-4-RSE-2
(solenoid)
SS-2-ME
(needle valve)
SS-2c2-1/3 (male threaded check valve)
SS-6MO-7-2
SS-6M5-4M
Optional:
B-4-HLN-2.00
B-4-RSE-2
SOlenoid
B-2-ME
B-2-HN
B-2c4-1/3 (female threaded check valve)
B-6MO-1-2
B-6M5-4M
The same configuration can be used for the GPT/HPT270 Victor models with a 90* output:
This one has a JBJ bubble counter instead of a Swagelok Tube Adapter:
This is my current set-up (a Victor SGT500 with full stainless post body) (notice the Swagelok Tube Adapter instead of a JBJ bubble counter):
I also recommend using a glass ADA bubble counter, the ADA gray or clear parts kit, and ADA pressure resistant tubing (4mm/6mm) coupled with a Swagelok tube adapter. This will prevent leaks. The JBJ bubble counter is a weak link. Here is what the recommended ADA configuration looks like:
For the other parts, see below:
Ideal Valve
Stainless: V54-1-12
Brass: V52-1-12
Call Bill Sand to order
hone (701) 352-1164
[email protected]
Burkert Solenoid
B-4-HRN-2
B-2-SE
B-2-HN
B-2-HN
B-6MO-1-2
B-6M5-4M
Or
My favorite way:
B-4-HRN-2
B-2-SE
(solenoid)
B-2-NH
(needle valve)
B-6MO-7-2
B-6M5-4M
B-4-HRN-2
B-2-SE
(Solenoid)
B-2-HN
(Needle Valve)
B-2C2-1/3
JBJ BUBBLE COUNTER
SS-4-HLN-2.00
SS-4-RSE-2
(solenoid)
SS-2-ME
(needle valve)
SS-6MO-7-2
SS-6M5-4M
Optional:
B-4-HLN-2.00
B-4-RSE-2
SOlenoid
B-2-ME
B-2-HN
B-6MO-1-2
B-6M5-4M
Ideal Valve
Stainless: V54-1-12
Brass: V52-1-12
[email protected]
Burkert Solenoid
