Basic question about Fe lasting in water
Discussion in 'Estimative Index' started by fablau, Nov 22, 2015.
  1. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Hello everyone.
    I have a question about Fe. I know that Fe ETDA and gluconate don't last long, whereas DTPA last longer in water... But in any case, any Fe source shouldn't last more than 48 hours. If that's correct, how is it possible that I can measure high concentrations of Fe (1-2ppm) with a colorimeter even after several days from the last dose?
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    This is something that I've wondered about, too. Does the test detect precipitated iron as well as free and chelated forms? Or does it only detect free and chelated? One way to test is to add iron and enough phosphate to precipitate them, then test again. If it detects iron, then precipitated forms are also measured.
    Another way to test is to simply add the Fe chelate and phosphate and just wait to see if precipitation occurs.
  3. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Good idea Solcielo, I can try your suggested test, but if the latter is true (the colorimeter detects just free and chelated Fe) that would contradict the idea that chelated Fe lasts just a few hours in water... Therefore, if that's a fact (that chelated Fe doesn't last long in water) the colorimeter must measure precipitated Fe. But if so, why can I detect and measure "plant intake" for days after the dose? I mean, plants shouldn't intake precipitated Fe right? And then, why do I see it decreasing daily? One idea contraddicts the other...
    I hope what I wrote makes sense...
    #3 fablau, Nov 22, 2015
  4. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    Since I had my water tested, I suspected as you did, that it really doesn't precipitate as assumed. Iron EDTA and DTPA are both stable for at least several weeks. If confirmed, then I wish I bought EDTA since it was cheaper and doesn't stain the water as much as DTPA does.
    Also, precipitation will result in obvious precipitates that settle to the bottom, appearing as a fluffy tan-brown gunk.
    #4 Solcielo lawrencia, Nov 23, 2015
  5. burr740
    burr740 Micros Spiller
    Feb 16, 2015
    1,398
    1,298
    4:26 AM
    Also wondered about this. Ive read before that tests pick up both forms, no idea if that is accurate or not. Fablau's testing seems to suggest otherwise.
    I never see any of this in my tank, but the canister sponges sure do collect a lot.
  6. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Oh well, I didn't know that. I think that explains it then! Thanks!
  7. Pikez
    Pikez Rotala Killer!
    May 12, 2013
    1,962
    1,473
    10:26 AM
    Weeks?! I suspect hydroponics folks have addressed this. Any references?
    Interweb echo chamber says hours to days for EDTA and possibly a couple of days for DTPA.
  8. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Yes, that's what I read, and that's why I opened this thread... if it is really just hours and a couple of days, why I can still measure Fe after several days (7-10 or more) from dosing?
  9. UDGags
    Sep 13, 2009
    630
    37
    10:26 AM
    What type of colorimeter? They aren't that accurate for absolute values.
  10. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
  11. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    One way to test is to add Fe in the tank and take a water sample after it's been thoroughly circulated. Then after a few hours, test both the tank water and the sample. If the tank has lower iron than the sample, then that indicates it may be used up, or possibly adsorbed to the substrate or wood.
  12. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Good idea Solcielo, I'll try, but from my measurements so far, I see a regular daily decay of Fe of about 0.05ppm. That could be plant intake or other kind of absorption.
  13. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    For an experiment, I added KH2PO4 and FeDTPA into a test tube and mixed it. A day later, it has not precipitated.
    The water is stained slightly brown from the FeDTPA, though. Does Fe gluconate keep the water clear?
  14. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    No idea about gluconate, but I can try. I have some Flourish Iron around.
  15. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    More than two weeks later, FeDTPA has yet to precipitate.
  16. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    Ok, therefore we can assume it doesn't precipitate with Po4. Thanks for the info.
  17. burr740
    Feb 16, 2015
    1,398
    1,298
    4:26 AM
    But is it still in a form that can be used by plants at this point?
  18. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    10:26 AM
    It will still be FeDTPA.
  19. fablau
    Sep 13, 2008
    2,904
    624
    2:26 AM
    And this explains why I could still measure Fe in my tank with a colorimeter after 2 weeks of stop dosing any Fe.
  20. Tom Barr
    18,694
    728
    10:26 AM
    DTPA should last at least days, not 2, but more..........unless taken up by plants. Weeks for DTPA seems correct provided it does not get removed or if you dose leaner. Water changes would remove it.
