Bart Laurens recipe for DIY clay with CSMB root tabs?
deepgreen
Aug 4, 2017
81
61
Arizona
I am trying to find a cheap way to provide micros as root tabs and thought about clay balls with CSMB in the center similar to regular macro clay balls. However, I recently read that Bart Laurens makes his own clay powder plus CSMB root tabs. Does anybody happen to know his recipe, e.g how much CSMB per clay powder and what type of clay powder he uses? I could not find anything about it except what I wrote.
Pikez
Rotala Killer!
Moderator
May 12, 2013
1,962
1,473
I have not seen his formula. But from pictures on his website, he puts CSM+B into capsules and shoves them under needy plants. He does the same thing with clay balls. I don't know if he blends the CSM with clay balls...I never asked.
Reactions: deepgreen
deepgreen
Aug 4, 2017
81
61
Arizona
Thanks for the information. I will try to make a mixture of clay and CSM+B, dry it and use as root tabs. I hope this will lead to slow release of micros. I am interesting to see what happens if the roots take up the micros versus water column dosing.
Pikez
Rotala Killer!
Moderator
May 12, 2013
1,962
1,473
I posed this question to Bart over the weekend. He is going to update his website to clarify things. Will let you know when that happens.
FWIW, if you recall my most recent root-feeding experiment in the Rotala Kill Tanks, most plants were perfectly fine when their roots were directly touching the tablets which contain several thousand ppm of minerals. If you expose leaves to the same level of concentration, you'd burn them.
deepgreen
Aug 4, 2017
81
61
Arizona
I am looking forward to the update. Thanks again!
I remember that you pointed out the extremely high levels of minerals at the roots without any toxic effects. Maybe it is possible to provide the plants everything they need through the roots without the need to match exactly their preferences in the water column. Obviously, it is possible given the excellent results with fresh ADA AS and no additional water column fertilization.
