B-2MA2 swagelok needle valve
inkslinger
Dec 15, 2007
370
Has any one use this B-2MA2 needle valve with a JBJ bubble counter? Do you have any pic's
inkslinger
Dec 15, 2007
370
Will I ended up ordering my B-2MA2 with the 1/8 MNPT I should have it in a couple of weeks.
It's looks like the SS-2MA2
Swagelok
It should work find with the JBJ Bubble Counter
I just hope there is enough clearance from the Solenoid to fit the Bubble Counter with out any adopters?
charlie
Oct 25, 2006
101
Swagelok
This one is a double , but you will get the idea, can you tell me how much it cost you?
Edit : just noticed my valve is different, will leave it , as it might give you some visual
inkslinger
Dec 15, 2007
370
The B-2MA2 needle valve only coast $61.50 I could have pick it up but would have coast the same for GAS to do it , Shipping coast me $9.50
I don't know why they don't have it listed it's a special order. The SS-2MA2 coast $89.
Nice Pic charlie
inkslinger
Dec 15, 2007
370
This was brought to view:
1. Be certain valve is in the FULL OPEN position, and
system pressure is relieved.
2. Thread Jam Nut off Bonnet.
3. Slide Locking Sleeve above Bonnet Hex.
4. Using 5/8 in. wrench, tighten Bonnet to 25-30 in.-lb
(2.8 - 3.4 N•m) to compress packing (TFE Guide Ring).
5. Slide Locking Sleeve down over Bonnet Hex and Body
Hex (Body Extension Hex on MG and MGD models).
6. Tighten Jam Nut against Locking Sleeve.
7. Test valve for proper operation.
CAUTION: M Series valves are not designed for shut-off
I assume that it comes close for shipping and we have to open it up and locking it down for operation ?
I don't have a 5/8 tork wrench will finger tight and give it a tweak would be good enought for this?
inkslinger
Dec 15, 2007
370
Will I got my B-2MA2 and WOW it looks like a tank compared to my Clippard Needle Valve ! Well I called my local Swagelok store ask the Representative about the little note that came with the needle valve about the packing adjustment. He explane to me that for our application of CO2 BPS we should not have to do this adjustment at all we are not using pressure of 1000 psig (69 bar. This what I got of line:
Testing
Every Swagelok S, M, and L series metering valve is factory tested
with nitrogen at 1000 psig (69 bar). Shell testing is performed to a
requirement of no detectable leakage with a liquid leak detector.
Every Swagelok L series metering valve is tested for bubbletight
seat shutoff at 100 psig (6.8 bar) differential pressure.
He said that these needle valves are use for High Pressure application and after awhile they may get loose after awhile and these is just to reset it.
inkslinger
Dec 15, 2007
370
Well here it is some pic's of my new Swagelok B-2MA2 needle valve with a JBJ bubble counter , It's on a 5lb tank witch I should get a bigger tank and a pic of my Clippard Needle next to my new B-2MA2 Needle Valve.
