Hi guys
This is a heads up if you are looking for a high quality solenoid at a reasonable price for your pressurized CO2 systems. Bürkert is going to have two models of their 6011 1/8" NPT solenoids with Buna-N Seals for CO2 duty. Buna-N is the seal material used in paintball guns and holds up very well with CO2 use. One model will have a brass body and the other one will have a stainless steel body. They will be manufactured in Germany. Below are the specifications and the ordering information.
Left C
New Bürkert 6011 Buna-N solenoid part numbers, LED DIN part numbers and prices
These are all three 2506 DIN 120V LED DIN's. The model 008 403 (w/o circuitry) is the one recommended for our use. Do note that these solenoids come stock with a DIN connector that doesn't have an LED. The LED DIN connectors are optional. These is a one week lead time on these DIN connectors.
NOTE: If you want a solenoid with the LED DIN cable plug, you will have to order both the solenoid and the LED DIN. The solenoid does not come as stock with a cable plug.
**** Bürkert technical support told me that these 6011 solenoids are designed such that being energized 24/7 is not a problem.
6011 BUNA-N SOLENOID SPECIFICATIONS
00463938
00463939
__________________________________________________________________________________________________
Brett Easterling, at Bürkert, called me on 6/26/10 and told me that there are going to be two 6011 series solenoids available with Buna-N seals vs the Viton seals that usually come in them. Buna-N is very good for CO2 duty where Viton is just rated as good with CO2.
They will be based on their brass model numbers 456786 and their stainless steel model model number 457157. These have 1/8" NPT ports and are made for 120v/60Hz.
_________________________________________________________________________________________________________________________________________________________________________________
freshwatersystems.com will be carrying these solenoids for direct order from them.
This is the link to the two Buna-N solenoids and LED DIN cable plugs with and without a varistor at freshwatersystems.com. https://www.freshwatersystems.com/c-496-solenoid-valves.aspx
http://www.freshwatersystems.com/p-6016-22-miniature-solenoid-valve-brass-body.aspx
http://www.freshwatersystems.com/p-6015-22-miniature-solenoid-valve-stainless-steel-body.aspx
http://www.freshwatersystems.com/p-6017-cable-plug-to-din-43650-no-varistor.aspx
http://www.freshwatersystems.com/p-6018-cable-plug-to-din-43650-with-varistor.aspx
How to wire the 2056 cable plug and proper orientation of the solenoid. It is directional.
Wiring the Bürkert cable plug DIY: http://www.barrreport.com/showthread.php/7783-How-to-wire-a-Burkert-type-6011-solenoid
Make sure that you have the Bürkert solenoid in the proper orientation: http://www.barrreport.com/showthrea...ow-direction-is-important-in-preventing-leaks
Left C
- Bürkert 6011 material: BRASS: 00463938
- Bürkert 6011 material: STAINLESS STEEL: 00463939
- 120V model 008 403 has a LED w/o circuitry with a max 3A circuit rating
- 120V model 008 355 has a LED, varistor and rectifier with a max 1A circuit rating
- 120V model 008 409 has a LED and varistor with a max 3A circuit rating (A varistor is a type of surge protector and the rectifier changes the current from AC to DC.)
00463938
- material: BRASS
- description: 2/2-WAY MINI-SOLENOID VALVE, DIR. ACTING
- mat description: 6011-A02,0BBMSNM81-2-120/60-04 PD02
- type: 6011
- circuit function: A: 2/2-WAYS; NORMALLY CLOSED
- orifice size: 02,0: 5/64
- seal material: BB: NBR
- body material: MS: BR
- port connection: NM81: NPT1/8
- coil size: 2: 0,79 INCH
- voltage: 120V
- frequency: 60Hz
- power consumption: 4W
- Var1: PD02: UR (UL-RECOGNIZED)/CSA-APPROVAL
- technical data: PRESSURE
- pressure min: 0
- pressure max: 8
- technical data: FLOW-RATE
- KV: 0,110
00463939
- material: STAINLESS STEEL
- mat description: 6011-A02,0BBVANM81-2-120/60-04 PD02
- type: 6011
- body material: VA: SS
- voltage: 120V
- frequency: 60Hz
- pressure min: 0
- pressure max: 8
- KV: 0,110
