Bürkert 6011 solenoids with Buna seals ... available very soon
inkslinger
Dec 15, 2007
370
So ??
Brass Bürkert 6011 Solenoid Valve : 00463938 = $45.40 Price
2506 LED DIN model 008 403 (w/o circuitry) =$9.00
Thanks!!
:gw
hbosman
Oct 22, 2008
277
Leesburg VA USA
inkslinger;52879 said:
So ??
Thanks!!
:gw
Sounds like what I will get if my Parker dies. Thanks Left C and inkslinger.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
I have a Bürkert order form with Jennifer Martin's letterhead. You will need to fill out this form in order to place an order.
Just PM me with your email address and I will send it to you. I can't simply attach it to this thread because the form has too many KB for it to be attached.
NOTE: Please send email address with form request.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
You are very welcome, H.
In my mind, you could either order one now as an back-up or one for a newly created aquarium. It's better to be safe than sorry. Right? (Hehehehehehe..... )
That's what I've done. I have a brass and SS solenoid coming with a LED DIN for each one.
From my experience, I know that Bürkert solenoids work well. Their being able to run energized (open) for 24/7 is a big plus, overkill, for our use!
hbosman
Oct 22, 2008
277
Leesburg VA USA
I am tempted to order one now but, I'm superstitious. If I have a spare, it will never get used. If I don't have a spare, the original is more likely to fail. I'd rather not have an extra solenoid sitting next to my spare Victor dual stage that might not get used either. Will I sell my spare Victor? No way. Because as soon as I sell it, I will need another one and now days it will cost me much more. ;-)
When the Parker dies, I will just run CO2 24/7 until the Burkert comes in. I've run CO2 24/7 for a few years and didn't have any issues.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
Wow! ... You think just like I do. LOL
I'm superstitious too.
inkslinger
Dec 15, 2007
370
I email my Burker rep and this is what I got back: Burket PN 463938 is $43.13 ea and comes with a std 2506 plug but has a 5-6 week lead time
However - PN 456786 is the same valve only it comes with a viton seal instead of a buna seal and I can sell for the same price
Lead time is about 1 week
The above Burket valve also comes with a std plug - but it looks like you want a special 2506 plug
Special 2506 plug PN 008403 Your Price: $8.55 ea
1 week
Beside being able to pick up locally,, Is the Viton seal any better than the a Buna seal for our purpose or is the Viton seal the older version solenoid and the Buna the newer version??
Left C
Sep 26, 2005
2,500
69
Burlington, NC
No price increase is right.
inkslinger;53001 said:
However - PN 00456786 is the same valve only it comes with a viton seal instead of a buna seal and I can sell for the same price
Left C;52347 said:
A plus is that there is no price increase for the Buna seals.
You can get one from aquariumplants.com with the Viton seal for $49 with free shipping. They are supposed to be in stock. But, they have the std DIN and not the LED model. They are not the [HASHTAG]#00456786[/HASHTAG], but a slightly different model, I believe.
1 week
I've been using one, a [HASHTAG]#00456786[/HASHTAG], for three years now w/o problems.
They are very good solenoids. They are even designed so that continuous duty being on is not a problem.
Left C;52347 said:
Bürkert says that it's not that the Viton seals are bad; it's just that the Buna-N seals are better than Viton for CO2 use.
My 456786 with Viton seals is about 3 years old and I haven't had any trouble with it at all.
Oreo and myself added a little more info about Buna-N and Viton below.
Left C
Sep 26, 2005
2,500
69
Burlington, NC
inkslinger;53017 said:
:gw
No I got it!! The Buna seal is better than the Viton seal for CO2 purpose .
Do you have one (or more) on order?
Have you seen them? They're about 2/3's the size of Clippard's solenoid, but more sturdily built.
inkslinger
Dec 15, 2007
370
No I just order the Special 2506 plug PN 008403 Price: $8.55
When I get a chance, I mean more money, I will get the other
I'm lucky I don't pay for shipping , I get to pick up local
Left C
Sep 26, 2005
2,500
69
Burlington, NC
... Beside being able to pick up locally,, Is the Viton seal any better than the a Buna seal for our purpose or is the Viton seal the older version solenoid and the Buna the newer version??
Buna-N
Nitrile rubber is the general term for acrylonitrile butadiene terpolymer. Nitrile O-rings, aka Buna-N, are a common rubber compound with two properties important to O-ring seals - resistance to CO2 (both liquid and gaseous) and certain oil based lubricants (like automatic transmission fluid). Nitrile O-rings have a medium to high abrasion resistance, and are resistant to most petroleum based lubricants. Nitrile O-rings also have a very broad temperature range: -65F to +275F, perfect for dealing with cold liquids like CO2.
Viton
Viton is a brand of synthetic rubber and fluoropolymer elastomer commonly used in O-rings and other molded or extruded goods. The name is a registered trademark of DuPont Performance Elastomers L.L.C.. It is rated only as 'good' for use with wet or dry CO2 and not excellent like Buna-N is. Viton works excellent at higher temperatures and exhibits excellent chemical resistance. It works well over a broader range of conditions than other elastomers. It is the closest available approach to being an universal elastomer for sealing in the use of O-rings and custom seals than other elastomers.
http://www.dkirubber.com/materials.asp
http://www.oringsusa.com/html/paintgun.htm
http://www.tankorings.com/aboutorings.html
Oreo
May 6, 2010
251
When it comes to CO2, Buna-N is what everything else is measured by. There really isn't anything better. Having said that, Viton is up to the task, and if you already have a Viton sealed solenoid valve don't go out of your way to replace it just to get one with Buna-N. I read somewhere that in the long run (years) Viton would develop mild surface oxidation when exposed to CO2.
inkslinger
Dec 15, 2007
370
Will just pick up my Special 2506 plug PN 008403 , The instrction comes on the package it's in German , It's for a 3 prong power cord now got to remember green,white,black? " ground , + , - " ?
