Availability of micro and macro from water PH
borman
Dec 29, 2007
58
45
Zaporozhye, Ukraine
I found an interesting table that shows the availability of micro and macro elements for plants, depending on the water PH.
I am particularly interested in the dependence of PO4.
Because I have a very low PH. (5,0-5,8) while I dose out quite a few phosphates (try to maintain a level of 1.0). And while I have GSA on my glass , and some plants show signs of lack of phosphate
any thought are welcome
More "P"
While local dogma holds that pH is not relevant, I will offer my ever-humble plant opinion and wait for it to be corrected. :eek:
I think that chart indicates what I have seen. In general, I take it to mean that at lower pH values we need to increase the ‘P’ (Phosphorous).
Personally, I maintain a higher phosphate level. :)
A ‘trick’ with GSA is at a water change, before refilling, scrape and wipe away as much as you can, credit card and toothbrush are handy. Take a phosphate solution (10-15 ppm) and squirt it on the glass wiping the glass and any expose surface down to the substrate, then refill. Another water change in two days is a good idea.
In aquatic systems, it's likely better to focus more on KH, less on pH.
There's some correlation obviously, but less KH will mean some things are better in solutions.
Still, plants are pretty tough and adding CO2 helps them far more than terrestrial systems and tables such as the one above, most tables etc are not for aquatic systems, so you have to be careful and not use them or apply them without question.
