Auto Dosing right nutrient concentrations
kakulo83
Sep 8, 2005
Hi all, I will be leaving soon for Germany and currently I am trying to set up an auto doser for my 65gallon (approx 60gal). The tank is heavily planted with fast growers, is CO2 supplemented, and has 6watt/gallon. I've checked Chucks calculator and the APC fertilator and decided with the following:
30240ml of water with 100 tsp KNO3, 100 tsp K2SO4. If I plugged the right #s, each 1ml of solution I add should give me .05ppm NO3 and .07ppm K. I will add 200ml every day.
Question 1). I have access right now to only Fleet Enema, how much should
I add to the 30240ml of water so that with 200ml I am adding
an appropriate amount?
Question 2). 100 tsp of either KNO3 and/or 100 K2SO4 seems like a lot, will
it be able to dissolve in room temp water?
Any information will be greatly appreciated. I have worked hard to make this 6watt/gallon tank work without too much algae. I would really be disappointed if I come home to fat plecos. Thanks again.
798
Re: Auto Dosing right nutrient concentrations
How big is the tank, what is the dosing rate of the dosing pump?
kakulo83
Sep 8, 2005
Hi Tom, the aquarium is 65gal roughly 60gals. Nutrient mix is in a plastic storage container filled with ~30240ml of water. Peristaltic pump is APT SP100, flow rate is .9ml/min, I have yet to measure the rate for my setup. Would you recommend that I decrease my lighting while away? Will going from a high to low tech damage plants?
