Well, critical thinking is a skill and it spans many fields of work/academia/blue collar trades(I spent 18 years doing such work), English lit, Philosophy, it's far from the exclusive domain of a botanist hiding in some swamp. haha
I did not scare you away with my false crotchetiness?
I'll try harder next time
Feathers get ruffled on line easily.
Ego's get bruised, some never heal.
Then they have it in for you from then on....
I'm not worried, I just keep going.
Thank you so much. I feel so silly for not having looked at the gauges.
Oh heck, you and me both, we and everyone here is very capable of doing this, it's a good lesson for you and everyone, myself also, we all are human and try to do things to prevent our feeble incompetence from getting the better of us.
Heck, I have to. I'd mess everything up otherwise.
Prevention is the key.
But after making the same mistakes a few times, we learn and do not keep doing them, well ............hopefully
That is how we learn.
We are all in the same boat.
I've just made the mistakes first or a few times more than you.........
So never apologize for learning.
I think as a good teacher, one should teach folks what they need to know with the least amount of pain as possible, but it requires effort to do that effective on both parts.
Mistakes will be made, at least we are not graded here
I tend to give lots of tough questions and work, but you get results for it.
And that process can be applied to many things outside this hobby/class etc.
I'll bet the pressure was low for awhile, because the tank had stopped pearling before the algae showed up. There were definately some bubbles in the counter, but clearly not enough and I'll bet not consistently.
Vaughn's gadget will help, but the truth is so will just looking at the tank! I was starting to research if the wavelengths of light had changed with older bulbs. I really do feel silly. .. Oh, and the last three weeks, I had a much easier time pruning. Oh the sheer folly..
Well, when you see the pearling slow down, alarms, bells and fog horns should go off. The plants are the best test kits for me, and that's why I can tell most of the time with very little information what is going on.
Algae are the next test kit.
The rest is just having done enough dosing routines and algae inducements to know what effects can cause these things.
EI is nice because it isolates and reduces the work for folks wonder if they have something else going on.
Then they see CO2 for what is truly is in the role and control of the growth and regulation of the plant.
Adding CO2 is not particularly natural, it's plain horticulture amplification, when you do that, the rules change for the nutrients as well, you need a lot more to keep up with the CO2, then the CO2 uptake increases and you get this back and forth effect, but it evens out once you isolate the nutrients well, then tweak the CO2.
If you have trouble, less, not more light is the key in slowing things down.
It's rare you see me telling folks to add new bulbs and more light unless they are way down on the very bottom end. Even then it's rare.
