Are My EI Dosing Regimen Correct ? Kindly Guide me :(
Discussion in 'Estimative Index' started by kingdamm, Apr 16, 2013.
  1. kingdamm
    kingdamm Junior Poster
    Jul 18, 2011
    17
    6:51 AM
    Hello Friends,
    Iam maintaining an 70 gallon thickly Planted Aquarium for 2 months. Till this day am :( struggling with Green Spot Algae, Blue Green Algae, Stunted Growth, especially Staurogyne with Leaf holes often breaks and floats hmm:(
    Here are the detailed parameters of my entire setup.Experts Kindly guide me what should i do to make them grow back healthier and free from algae.
    Following EI Dosing as stated below with 50% water change every week
    Macro Stock Solution & Dosing
    1.) KNO3 - Dissolving 80gm in 1000ml of Distilled water. Dosing them 40ml x 3 times a week for achieving 20ppm
    2.) KH2PO4 - Dissolving 30gm in 1000ml of Distilled water. Dosing them 20ml x 3 times a week for achieving 3ppm
    3.) K2SO4 - Dissolving 80gm in 1000ml of Distilled water. Dosing them 75ml x 3 times a week for achieving 30ppm
    Micro Stock Solution & Dosing
    1.)Plantex Csm+B -Dissolving 120gm in 1000ml of Distilled Water.Dosing them 15ml x 3 times a week..
    Lighting Details
    4 X 50W Cree XPG LED FLOODLIGHT 6500K RUNNING FOR 6 HRS 30 MIN
    Substrate
    ADA Amazonia II with Powersand (using them for about 2 yrs)
    C02
    Pressurized Co2 @ 5-6 BPS until Co2 indicator turns Lime yellow in color.
    Filtration
    Canister Filter 1600l/hr Flow
    Hang on Filter 1000l/hr Flow
    Temperature
    Maintained @ 28 degree using Jebo Cooling Fan
    Here are My Water Parameters
    PH After CO2 Injection = 6.7
    KH = 3 degree
    GH = 5 degree
    Flora = Staurogyne Repens , Rotala Colorata , Pogostemon Helferi, Rotala Indica ,Ludwigia repens, Hair grass , Alternanthera Reickini , Rotala Macrandra Narrow, Christmas Moss..
    Fauna = Ottos -6 , Cardinals -5 , Amano Shrimp -5 , Pencil fish -10 & Siamese Algae eater -10
    Looking for all your kind support and guidance...
    Regards..
  2. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,867
    623
    10:51 PM
    I see this is a old thread, and I am surprised no one has ever replied... And maybe by now you figured out by yourself.
    From your detailed parameter list, I would try to reduce light 1/4 and increase light time ( from 6 hours to 7-8). Also, I see your GH is pretty low, so you may want to add some GH booster to be sure not to runout of magnesium.
    What else?
