Aquavitro Envy
NanoNana
Feb 27, 2022
6
Florida
I appreciate the contents in this website very much. I use the nutrient calculator and need assistance with Aquavitro Envy dosing. Would it be possible to add this item in the menu along with the other four AV products? Thank you. Also if anyone can tell me how to calculate EI dosing or lead me to a good discussing, I would very much appreciate it.
Allwissend
Super Moderator
Moderator
827
368
63
www.intuitiveaqua.net
Aquavitro are rebranded and reimagined Seachem diluted products. Similar to Seachem old line it will get rather expensive to dose EI with them.
Aquavitro Envy is dead algae (chlorella) with some extra vitamin C and others , not a mineral fertilizer. Doubt it will ever be added to the calculator. It's not needed to grow plants, it's not need for EI.
The other Aquavitro products are present in the calculator and can be used to figure EI dosing. Configure the calculator like this for each of their product , with your volume of course:
You can find out more about EI here : Original Estimative Index article: https://barrreport.com/articles/the-estimative-index-of-dosing-or-no-need-for-test-kits.38/
NanoNana
Feb 27, 2022
6
Florida
Thank you so much! I did not know that. According to the label, it addresses the micro and trace requirements. So I thought its all I need for micro. I have their other products for NPK.
NanoNana
Feb 27, 2022
6
Florida
I might have to try a different micro fert brand since the ingredients is a little iffy. What would you recommend ?
Allwissend
Super Moderator
Moderator
827
368
63
My recommendation would be to get NilocG , Select Salts Plantex CSM+B . These are dry compounds that need to be mixed with distilled water to make the solutions for your aquarium. The advantage here is that you don't have to pay or ship water water. You can use the instruction on the package or adjust your dose according to https://rotalabutterfly.com/nutrient-calculator.php .
Admittedly, mixing up is not for everybody... mainly a convenience and confidence issue, so I would then recommend Tropica Premium as a source of micronutrients. If you want to stick with Seachem products , Seachem Flourish is mostly micronutrients.
