AQUA-MEDIC-AM 1000 Water Leaking at CO-2 tubing connection(s)
Discussion in 'Fish for Planted Tanks' started by biiise, Jun 1, 2017.
  1. biiise
    biiise Junior Poster
    Mar 19, 2015
    1:21 PM
    On first connection to filter water poured out from the quick disconnect device for the CO-2 tubing and the Air purging connection which also is connected via CO-2 quick disconnect. There was "play" in the connection. The second trial was in the tub with the CO-2 tubing put in tightly on one side so that there was no play and this did not leak. The other side did leak but I didn't have the same CO-2 tubing and it was difficult to get it to fit as tight. I have never used these type of connections except a similar type on the Spectra-Pure R/O unit. I'm afraid I'm going about this the wrong way and don't want my tank contents to leak even a little. I'm using vinyl-flex 18/14 tubing which came with my CO-2 regulator if that matters.
  2. PhilipS
    PhilipS Lifetime Members
    May 10, 2014
    253
    23
    5:21 AM
    Is the hose CO2 hose?
    Always put in a CO2 approved check valve inline closest to the regulator/solenoid to prevent water getting sucked into the mechanisms due to the vacuum created.
    Only hard type hose seems to work with those push-in fittings.
    I have only used the compression nut type solenoid fittings and splitters.
    Finally dialed the CO2 in, and approaching one year since refill.
  3. biiise
    Mar 19, 2015
    1:21 PM
    Thank You
    Philip...I checked on responses for several days so didn't think anyone responded. I had a lot going on in other areas of life so am now getting back to this device so I will be ordering some other tubing for hook up. Thanks for taking the time to respond !
    Bill
