Approximate PPM per dose?
longhornxtreme
Hi all,
I was wondering if anyone could tell me what the approximate PPM added to the tank for N,P,K for each dose (3x a week)? I'm wanting to mix up my own solutions to work with and I can do the rest of the math myself, but I don't know how many Grams are in each teaspoon measurement.
Thanks in advance
799
All dosing calculators have them built in.
So you can use those.
You can also use a density of the substance and that the 1/4 teaspoon = 5mls or 5 cc's.
Per week:
I generally add about 20-30ppm of NO3 via KNO3, maybe less if the fish loading/feeding is high or light is low etc.
I add about 3 ppm of PO4.
And about 20mls of Traces(TMG as a standard) per 80 liters of tank volume.
That should provide non limiting levels and with a weekly 50% water change, you are not going to build up that high.
If you wish to target specific ppm's, then you should use the EI dosing cal:
Nutri-Calc[v1.9.3 Mar 10/07]: an EI Dosing Calculator & Tank Size Calc
http://www.cherniaksoftware.com/home.../NutriCalc.exe
Or use the search function here.
It should pop up.
longhornxtreme
Well... it seems that the nutri calc link is dead.
Thanks for your explanation Tom. I've got my micro dosing sorted out, I just wanted to try out your macro dosing for a bit. I use a combination of CSMB and Flourish for micros, and as soon as what I have left runs out I'll try out TMG.
So it's safe to say that each dose should have
20 - 30 ppm NO3 a week / 3 doses = ~8ppm NO3 / dose
3 ppm PO4 a week / 3 doses = ~ 1 ppm PO4 / dose
I tend not to trust calculators for these simple chemistry calculations as either the software is buggy, or a decimal place is off etc. Gives me a reason to use my chemistry minor for fun.
THanks!
799
THanks!
Good old school is the best.
I still do it that way, even with spread sheets and all.
Old habits.
tim85
Feb 7, 2009
17
Tom Barr;22568 said:
Per week:
I have just started dosing 3tsp KNO3 and 1tsp KH2PO4 for my 180g on Sundays (50% wc) , Tuesdays and Thurdays. I also put in 1tsp CSM+B on Mondays, Wednesdays and Fridays.
According to Chuck's calculator I am doing like 15ppm NO3 and 5ppm PO4 on EACH of the 3 days of dosing. I have 1.6wpg of light and pressurized CO2. Fish load is low. Am I dosing too much ?
ccLansman
Jan 22, 2008
375
Vista, Ca
YES, your light is low. I would watch out, 1 tsp KH2 seems over kill, if its 1/2 KN03 to 1/8KH2 on a 60 gal, if we x3 for 3x the tank vol i would see 1.5 and 3/8...
timmo11
Sep 3, 2007
13
Tom I think this is a typo unless US teaspoons giant sized?
1/4 metric teasponn = 1.25mL
Tim
799
Yes, 1.25mls not 5mls, yes, it's a typo. Thanks for catching it.
Reagrds,
Martin
149
46
Sebbersund, Denmark
In Nutricalc... do you guys know the percentage of N in KNO3 etc?
the ferts sold in the States differ quite a lot from what I can buy..
here it's 13,7%N I believe it is a lot higher in the States?
what % does Nutricalc use?
799
% N or % NO3?
That will make a large difference.
Most talk about NO3 ppm's, not N. Research tends to talk N and farmers do as well.
14 grams/mol for N, 101gram/mol for KN03=> ~ about 13.9% N, per gram of KNO3.
Sounds like the same stuff, KNO3 is KNO3 the world over.
Martin
149
46
Sebbersund, Denmark
Hi Tom..
Well.. when looking at Chuck's calculator he lists it as:
K - Potassium 38.7%
NO3 - Nitrate 61.3%
I'm talkin NO3 of course..
