Any experience with a Kent Marine venturi?
R
Russ
I just bought a Kent Marine Turbo Venturi and I'm going to place it in line with my Eheim. I'd appreciate any advice people may have about using one for CO2 injection. Here's a link to the model I bought: https://www.petsolutions.com/Turbo+Venturi+Valve-I-12515435-I-C-28-C-.aspx
Initially, I'll probably place it after the filter to avoid potential problems with noise, filter gaskets and effects on the biofilter that Tom and Richard bring up in my thread on using an Eheim as a reactor.
Thanks,
-Russ
18,696
755
These are fairly cheap and a few folks have used thenm, although many that have used this particular method have mainly used the best mazzii venturi valves they could find.
I opted for those rather than these cheaper alternatives, but folks are certainly going to try these in lieu.
R
Russ
I'll do a post regarding how well I think it works.
-Russ
R
Russ
Well, I finally blundered into the thread on Mazzei venturis under 'Articles.' That was a good read - only now I want one of them fancy Mazzei venturis.
-Russ
18,696
755
Well 17$ vs 35$ is what you are talking about.
I have no issue with it.
It's the method and theory I like.
I use these for large gaint tanks with amazing results.
So does MBA.
R
Russ
Here's a mundane question, but one I could use some help on. The gas nipple on the Kent venturi is 1/4" but my CO2 system is set up for and I'm using 3/16" tubing. Is there a simple way to make the connection?
18,696
755
They sell hard nylon adaptors at Home Depot for less than 1$.
Bring the 1/4" and the CO2 tubing with you also to the hardware store.
wiste
Where can you find Mazzei Venturi Injectors for 35$?
Seems more like 17$ vs 76$ (1/2"). Not an exact comparison as the 76$ does include a check valve on the gas inlet.
IUnknown
61
I used the Kent Venturi. I was going to look at my notes tonight to
remember exactly what I did not like about it. The orifice if I
remember is bigger then the mazzei, so it requires less pressure differential
to work. But the hole for the Co2 port is much bigger, so the bubble
size is not really mist and is distracting to the aquascape. Also the
fitting loss was not good on the Kent Venturi, where as with the Mazzei,
it's not noticable.
Check out Ryan Herco.com. Also email the mazzei engineer with your pump head pressure and flow rate and he is really good about sizing an injector for you. I'm working on a graph so that people can size the injectors given a certain head pressure and flow rate.
DIY In-Line Micro-bubbler - Page 9 - The Planted Tank Forum
