Anubias bulb with no leaves but has a lot of roots
Discussion in 'General Plant Topics' started by rs18alpha, Oct 2, 2017.
  1. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    240
    25
    9:49 PM
    I just set up a new tank. I have an old Anubias plant that I put in a temp tank.The bulb is floating right now. It has several old leaves on it with a lot of roots. I have several fry that like to hide in the roots.
    I was going to put it back in the new tank, but I want to cut the leaves off and let the bulb float with all the roots still intact so the fry can hang out under it. If I cut off the old leaves will it still produce new leaves?
  2. Mooner
    Mooner Lifetime Charter Member
    Jun 9, 2006
    301
    9:49 PM
    Snap off, not cut, Anubias leave/stem at rhizome. New leaves will be produced from rhizome. I’ve never floated them, only tied to wood and rock.
Tags:
