Hi, thanks for this site and all the things i've learn and will learn here.
So as i'm heading to add a 112 galon tank (60lx24wx18h) to my house
and i know little about plumping, pipes and most of all wet/dries filters, I'm a litle confused about some things. I know this questions may have been answered before, have read some post about wet/dry, but most of them, with no offense at all, are in space rocket science language to me.
well to the point, i want to have this time a wet/dry filter as main filtration (and a fluval 305 as additional), these are the question i need to clear up :
1. for my tank i'm planning to have a CPR overflow box, the CS90DX to be exact. you said on another post that using a larger overflow is better, so do you recommend that i buy the CS100DX model instead?
2. On that same reasoning, i plan to get a Rio plus 3100 pump, if i change that overflow model should i get a stronger pump? the distance from the display tank to the sump will not be more than 4' foot
3. the w/d will have 30x16x16=33g of volume, is this good?
4. the filter will be diy and i've this primitive design in mind, what do you think? what do i need to improve?
