I've gone pretty much all venturi as I can take the powerhead out of the tank entirely whether I have a canister or a a wet/dry sump etc.
Since the venturi is in line or feed into the return pump, the mix and blowing around of the mist is already in one efficient flow source.
No need to add something else in the tank.
Also, for smaller tanks, a simple Adaptor tee works well and does not reduce flow rates at all. If you have a longer return line, then the bubbles will get more dissolved and ground up, larger tanks with more pump power: mazzei work well.
Sumps can be feed from a dual needle wheel impeller style method, feed the CO2 into a small powerhead or needle wheel Gen X pump, then feed the outflow directly into the main return pump intake.
Or you can use a small mazzei(still need the pump to drive it, so may as well use a needle wheel for this)
If you like a diffuser disc in the tank, then that's fine as well.
But they all do the same thing when correctly set up.
For smaller tanks without canisters, the disc are fine/practical.
Tom barr
