Another iron dosing questions
Discussion in 'Aquatic Plant Fertilization' started by Benealing, Apr 24, 2015.
  1. Benealing
    Benealing Junior Poster
    Feb 19, 2015
    13
    2:17 PM
    I know I should be able to do this math, but for whatever reason, I just cannot figure out how to do it.
    I want to dose EI in my 75 gallon. I am going to dose CSM+B and 10% DTPA Iron.
    I found that the ratio is supposed to be 3 parts CSB to 2 parts DTPA.
    I want to mix up a solution in a 500ml bottle and dose 20ml every other day.
    Can someone help me figure out how much of each of these I need to add to make my solution?
    My math came up with 32.6grams of CSM and 14.2 grams of DTPA.
    Does this seem correct?
    Does this amount of CSM+B give enough of the rest of the micros?
    Ben
    #1 Benealing, Apr 24, 2015
  2. PhilipS
    PhilipS Lifetime Members
    May 10, 2014
    256
    23
    6:17 AM
    Dosing calculator rota.la choose EI Daily
