Am 1000
793
Yes, should be a good pump for the job.
yme
643
19
although in my hands, the AM1000 reactor itself cannot keep the pH sufficiently low... I need the addition of the rhinox difussors.
greets,
yme
jonny_ftm
Mar 5, 2009
821
Tom is clearly better used with this reactor, but I'm not sure a 79gph pump will be enough for the AM1000 on a 80gal tank. You'll need a high bps count on the AM for your tank. With a 79gph pump a build up can occur quiet rapidely
yme
643
19
your inbox is full :D
I have a 90 gallon tank. the eheim is ype 1060.
greets,
yme
hani
302
should i run the pump before or after the reactor, i tried both ways, if i run it before the i can de-gas back to the reactor, the disadvantage in this way is the tubing more likly to kink leaving the pump back to the reactor top, if i run it after less tubing but can only de-gas back to the tank, any thoughts?
jonny_ftm
Mar 5, 2009
821
I don't degas and it works like a charm. If too much gas builds up, then reactor is unable to keep with too much CO2 or maybe not enough strong pump.
If you like still to degas, better will be in reactor of course. Maybe try to better adapt your tubing path to avoid kinks. A photo of your setup could help us to advice you
