Aluminium Oxide grit as top coat
Discussion in 'Sediment / Substrate' started by leo28n2000, Nov 10, 2017.
  1. leo28n2000
    leo28n2000 Junior Poster
    May 16, 2017
    7:10 PM
    Can I use Aluminium Oxide sandblasting grit of 1-3mm size as black sand gravel for a planted aquarium? I plan to use mineralised soil as nutrient rich base layer which would be covered by this black sand. We dont get Black Diamond sandblasting grit where I live and am looking for something thats dark black in colour and cheap too. I have heard that Al. Oxide is harmful only at Ph below 5, if so I think I should be able to use it. Please help. Thanks.
  2. ForTheHalibut
    ForTheHalibut Member
    Oct 12, 2017
    44
    10
    2:10 PM
    Using a mild neurotoxin as an aquarium substrate is probably not a great idea. Consider using pretty much anything else.
  3. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    479
    504
    2:10 PM
    Aluminum Oxide is usually the 2nd highest % content on any coal slag product.
    Coal slag is inert and the actual contents are not available in the water column.
    @burr740 is proof of this as are many of the rest of us.
    burr740 likes this.
