All new scape by Obbezz ( in need for some comments)
Discussion in 'Dutch' started by Obbezz, Jan 13, 2013.
  1. Obbezz
    Obbezz Prolific Poster
    Dec 16, 2010
    83
    6:16 PM
    Ok.. I will make some new stock solution Po4.. 4,3 gram po4 / 500ml water will add 0,25 ppm of Po4
  2. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    As promised herewith the new pics.. I tried to create a more sloping effect by increasing hight on both sides of the aquarium.. (it's being held back by black slate) this black slate will be not visible after planting.. What do you think dutchy..(more hight?)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  3. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    6:16 PM
    I think the height is ok but the big stone on the left attracks more attention than the path to the back in the middle. Do you have a little bit smaller one? You can push the slate a little bit more downward until it's almost not visible.
    #23 dutchy, Jan 18, 2013
  4. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Unfortunatly I ran out of stones...(i ordered 13kg and managed to get them all in there)
  5. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Maybe if i place some plants in front of the stone it will be less destracting to the path!
  6. dutchy
    Jul 6, 2009
    6:16 PM
    Well, it's all about balance. Look at it and ask yourself if it is balanced. That's the best way.
  7. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Here a small update regarding my scape.. diatoms are still present but after 2 weeks i think it’s getting better…
    Plant growth is not that good.. the hygrophile polysperma that normally needs trimming every week is still adjusting and is showing signs of deficiency.
    The new planted blyxa japonica is melting on the bottom of the plant.. downoi is melting..
    So hopefully the plant growth will pick up soon..
    Schedule :
    Tuesday: Cleaning the tank, 50% water change, 25ml profito, no3
    Wednesday: po4, easycarbo
    Thursday: no3, 20 ml profito
    Friday: po4
    Saturday and Sunday : Nothing
    Monday: profito : 20 ml.
    Co2: 40 + mg/l
    Target values no3: 20-30 mg/l
    Po4: 0,25 – 1,0 mg/l (because of diatoms)
    Lights : 2 x 28 watt : 9 hours a day.
    Any advice?
    Herewith a pic…
    https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/578078_401440516612155_1165912375_n.jpg
    [/img
  8. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Just wondering if somebody/anybody could give me some advice or tips?
    Hope 2 hear from u soon..
  9. dutchy
    Jul 6, 2009
    6:16 PM
    I have to say the overall pic looks nice.
    If Blyxa and downoi are melting you can be sure there's a CO2 deficiency. Mind that the wood releases a lot of tannins, which lower pH. This lower pH can not be related to CO2 ppm's.
    Result is that you might have a lot less CO2 than you think.
    I also have a lot of wood in my tank. The CO2 level is theoretically at 100 ppm..... The drop checker says I have around 40 ppm. If I use a pH which gives me a theoretical 40 ppm the plants will melt.
  10. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Thank you for your reply Dutchy! I have the co2 long term test from Dennerle.. it's pretty yellow..
    (maybe 2much co2)?
    Most of the plants slightly moving by the current of the filter.. (so i think i'm good there)
    maybe i have to be patient and wait for a few weeks 2 see what's happening..
  11. dutchy
    Jul 6, 2009
    6:16 PM
    Plants are never limited by high CO2, unless you can go higher than 10.000 ppm... :)
    Blyxa is a weed if it gets enough CO2, but will melt if not...
    Remember that light is also a player here. Your yellow drop checker might still be not enough. Your plants tell you exactly what they need.
    I'd add more CO2 or lower light.
    #31 dutchy, Feb 19, 2013
  12. Obbezz
    Dec 16, 2010
    83
    6:16 PM
    Ok.. will try both options.. (i thought that 2 x 28watt is not heavy lighting for this size tank)
    will keep you informed!
    Thanks Dutchy!
Similar Threads - scape Obbezz need
  1. Obbezz
    56
    1,012
  2. mexicatz
    329
  3. Mikymn
    488
  4. iwannagofast
    519
  5. mexicatz
    786
