Algae Problems!
Discussion in 'General Plant Topics' started by gabcas0319, Nov 6, 2016.
  1. gabcas0319
    gabcas0319 Junior Poster
    Aug 29, 2016
    78
    10:04 AM
    Hello! this is my low light tank! and right now it has algae! i want to know what the cause of this algaes! Ammonia? CO2 fuctiations? or deficity of nutrients? right now only adding potassium and iron! 1.5w/galon! thanks for the help
  2. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    2:04 AM
    Low light tanks can get algae easily too.
    Did you recently stir up organics?
    Do you have a lot of fish?
    How much are you dosing?
    Water changing?
    Just a few questions....
  3. Kyalgae
    Kyalgae Lifetime Members
    Aug 25, 2016
    347
    234
    5:04 AM
    I know the feeling, that staghorn crap is the worst, it sticks so tightly to the plant that you have to get rid of the leaf! Then you wonder why nothing has leaves... You have the exact same algaes that I have currently in my tank, how's the surface film on your tank? Do you have any? I'm waiting for a skimmer to come in the mail, I'm interested to see if lack of surface film will improve things.
  4. fablau
    fablau rotalabutterfly.com
    Staff Member Moderator
    Sep 13, 2008
    2,904
    624
    2:04 AM
    Likely deficiency of nutrients. What kind of light do you have? For how many hours a day? How much planted is your tank?
  5. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    i turn it from a only excel tank to a non co2! organics normal not to much! it just have like 5 cherrys! righ now im not dosing notting! when the lights ore off im goin to do a 100% water change clean all the algae and start to dose like 5-0.5-5 NPK!!! i have a question strungout! i have 2 filters good flow 5 cherrys! why i have problems of excess of amonnium? thanks!
  6. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    hahaha yeahh is a pain!!! yes i have a lot of biofilm im goin to put the filter out in the suface to move it!
  7. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    yes right now im not dosing notting but i will start today y hace compac fluorecent of 9 watts in a 5 gallon for 8 hour a day! is really really low biomas ! thanks
  8. Dennis Singh
    May 5, 2013
    2,417
    639
    2:04 AM
    Your problem isn't ammonium, its lighting, either too long or too bright. With your low plant biomass especially
  9. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    :( :( :( what is your advice strungout? :( i really want to make my tank works! shuld i lower or higher lights?
  10. Dennis Singh
    May 5, 2013
    2,417
    639
    2:04 AM
    Higher the lights sir :)
    meaning raising it higher, so you have lower light
  11. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    I will do it now!!! thaks strungout! really appreciated your advice!!!
  12. Dennis Singh
    May 5, 2013
    2,417
    639
    2:04 AM
    Your very welcome Gabriel
  13. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    i made it hehehehe :D :D:D also now that light are higher i add salvinia to add more biomass!
    Strungout! the last question! one more advice hehehe To avoid more algae do i shuld use excel? thanks for the help
  14. Dennis Singh
    May 5, 2013
    2,417
    639
    2:04 AM
    If u want to get rid of algae quicker and your shrimp to slow down a bit on breeding then yes. If u don't want to slow breeding then no. The algae will go away in time, takes patience but if your light is still too high then no.
  15. gabcas0319
    Aug 29, 2016
    78
    10:04 AM
    Just to weeks after youre advice and all cianobacteria is gone hehehe i'm winning against algaeee !!! yujuuuuu!!! thanks strungout really tanks!!!
