algae problem
Aug 18, 2010
122
Hi, i'm trying to identify this algae and what is causing it. Hope you can help me!
thanks a lot!
250l Aquarium
Photoperiod- 7 hours a day, with 8 t5 54w.
Co2-35 ppm
No ammonia
No nitrite
Adding KNO3, KHPO4, MgSo3, CaCO3, 3 times a week; CSM+B 3 times a week.
Thanks for helping!
ibanezfrelon
May 18, 2010
205
43
croatia
I think 4 t5's would still be very high light and a real challange to suply enough co2 to follow that amount of light.
This is WAAAAY too much light and i think you can't give the plants enough co2 to follow this light without killing fauna in your tank.
...unless those lights are stuck to the seeling few feet above the tank :)
Could you give the pitcure of the entire tank , and those 8 t5's?
I'd realy like to see that..
How do you disolve that co2? How much flow do you have? Filtration?
Reducing those lights , adjusting co2 would be the first step..
dutchy
62
The Netherlands
As Ibanez says you have way too much light. I can see like three different kinds of algae on your pics, which are related to CO2 difficiencies and NH4 spikes.
Your aquarium is 250 liters, mine is more than TWICE that size but I use only HALF of the amount of Watts that you have. And I have no algae. And this is the result:
Using 25% of your lights, so two tubes, maximum three, will put you in the same range, but will give you a better chance of being able to meet CO2 demands. The NH4 spikes can be avoided by not uprooting too much plants at the same time and always do a large waterchange afterwards.
regards,
dutchy
ismenio
Well, another one that have bender over is necks because the light.
I don´t now if you ´re Portuguese but at least here in Portugal most folk adore the good of light and the electricity here is one of the most overcharge.
Take the advice from ibanezfrelon and dutchy and cut the light.
Regards
Aug 18, 2010
122
Hi.
ibanezfrelon, here are the pics.
I disolve Co2 using a home made reactor connected to the main filter. The reactor is filled with bio-balls, in order to increase the water-gas surface. I have 2 aditional pumps to improve water circulation in the tank. The filter pump moves 2500l per hour. 8 Kg Co2 tank. I always keep my Co2 about 35 ppm but, if u are right and i'm understanding you, that ammount is not even enough to consume that light?
dutchy and ismenio, so are you agree on taking off a couple of t5s'?
I may exaggerated about the light, i just thought that more watts with a smaller photoperiod would help fighting algae in some cases.
How many hours a day you suggest?
Thank you guys, i hope you continue helping me.
(sorry about my english)
Regards.
dutchy
62
The Netherlands
Regards.
First: You can better tell us how it really is :gw:
As far as I can see the tank is kind of shallow (not very deep) Two T5's with a photoperiod of 10 hours will give you all the light you need and you will be able to grow every plant you want, without all the algae issues you have now.
regards,
dutchy
ismenio
Well, dutchy is right, i´m just a newbie but in the past i have the same problem, in a 40 L tank i put 48 W in T5 but without CO2, well, you can´t see even the fish, the glass was full of algae and the plants too.
Now i have a 80 L tank with one 24 W T5 bulb and diy CO2 and i don´t have algae.
Is better take the advice of dutchy, with that your pocket will thanks since the electricity bill gonna be smaller and you can decrease the co2 in the tank too was well the rest of the nutrients.
Regrads
Aug 18, 2010
122
Ok. I just take off 2 t5. Now i have 6 and changed the photoperiod to 6 hours, i will take off some tubes daily until the algae stops. Will see how it works. Yor're right guys.
So you think that the macros consumption in the aquarium will decrease?, in that case i have to recalculate the dosing of nutrients.
Regards, thanks again for helping
dutchy
62
The Netherlands
Con mucho gusto.
The nutrient consumption will decrease, but that's the least of your worries. Don't take back the CO2!! When you get back to using only 2 tubes, a total of 40 ppm of KNO3 and 4 ppm of KH2PO4 per week will be enough. Adjust the others accordingly.
Ciao,
dutchy
ismenio
No !!! Dutchy haven´t say to turn off two bulbs but to only turn on two bulbs and turn off the others six.
And by the way, do not decrease now the nutrients, neither co2 until the algae go away.
Regards
Aug 18, 2010
122
I know ismenio, the idea is to reduce more my light. I just want to do it slowly, in order to avoid drastic changes that may cause more imbalances. You're right, i'm not going to modify the fertilization for now, that may cause an other imbalance which for sure, will lead to another f$%&n algae!.
Thank you guys, i really apreciate your help.
Se nota que soy de habla hispana?
jaja!
Aug 18, 2010
122
Qué bueno!...Soy Colombiano también!....
I hope that your wife's nationality, develop special attention to my post. LOL
Regards!
I will tell you how my aquarium goes!
Aug 18, 2010
122
Hi guys...
Even reducing light and adjusting Co2 to 35-40ppm (Tested whit a DIY Drop Checker), this algae is growing faster. I looked at the algae through a microscope and i identified it as Urothrix.
(sorry about the pic)
Is amonnia causing this?, even if my test says 0?
What do you think? Need some help!!
Thanks!!
