Algae Help Please
Discussion in 'Algae Control' started by ElGecko, Feb 23, 2019.
  1. ElGecko
    ElGecko New Member
    Sep 16, 2018
    5:51 PM
    Hello and thank you in advance for your help.
    I have a 75 Gallon running the Fluval Plant LED 3.0 on Black Diamond Blasting Sand substrate. No Ammonia or Nitrite, but My Nitrates are always high (100+) according to API kit (note that it shows no Nitrate in clean tap water) I also dose Aquarium Coop Easy Green according to instructions as well as using Flourish Excel. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    I have what I believe is Green Spot Algae on rocks and leaves, and on glass when I don’t scrub. My cleaning crew consists of SAE, Ottos, Malaysian Trumpet Snails, Nerite Snails, and Ghost shrimp.
    Pics attached below, including photo period being used.
    I was going to bleach dip plants and rocks this weekend for control, but that’s not going to solve my underlying issue.
    HELP PLEASE!!
  2. RojoP
    RojoP New Member
    Feb 12, 2018
    5:51 PM
    I have read in another aquarium forum where Mr. Barr stated that at 1.5-2.0ppm or so of PO4 (phosphate ) green spot algae will drop off.
    (I have been having this problem too, but since I have lower light plants I am going to add some patches of window screen material to reduce my lighting).
